Nice set of nozzle-cleaning bits for $21
chippwalters
Post by chippwalters » Tue Sep 17, 2013 5:05 am
Thanks and most interesting. How often do you drill your nozzle? And, what is considered standard maintenance for an UP! printer?
Re: Nice set of nozzle-cleaning bits for $21
Post by JuliaDee » Tue Sep 17, 2013 12:21 pm
I've never actually drilled a nozzle, but in the past I've run a fine wire through them to clear clogs. I subsequently found that the most significant clogging actually occurs behind the 0.4mm aperture, in the "middle chamber", which is just big enough to twizzle a 1/16" bit around in. Cleaning the gunk out of there can make a big difference. That said, I haven't taken a nozzle off in months (knock on wood). The pass-the-filament-through-a-piece-of-foam trick seems to help a lot. I just thought these bits would be handy to have around in case of emergency.
julia
