Turn off support
Tiertime-Edward
Turn off support
Post by Tiertime-Edward » Thu Aug 01, 2013 8:04 am
Did you find new features in UP 2.0? One of some is you can start to turn off support complete by select ONLY BASE in print parameter -> Support -> Area -> ONLY BASE.
turn off support.jpg (33.98 KiB) Viewed 5654 times
wilsonj
Re: Turn off support
Post by wilsonj » Thu Aug 01, 2013 9:54 am
Hi Edward,
Yes I did see that, although I haven't tried it. So finally we can print whistles !!!
Great work!
Post by roller » Thu Aug 01, 2013 11:14 am
wilsonj wrote: Yes I did see that, although I haven't tried it. So finally we can print whistles !!!
Great work!
If our bridging is good enough ... fingers crossed!
amd-tec
Post by amd-tec » Thu Aug 01, 2013 8:31 pm
Edward wrote:Did you find new features in UP 2.0? One of some is you can start to turn off support complete by select ONLY BASE in print parameter -> Support -> Area -> ONLY BASE.
Is it working in older machines which use 2.0 software?
I didn`t find that option in my machine (I`m using 2.0 software).
http://www.amd-tec.com
LonV
Post by LonV » Fri Aug 02, 2013 5:06 am
Haha, I was sure this would print fine on my reprap first pass...and not even come close on my Afinia (Up! Plus). :P I was wrong.
Reprap was a mess (currently trying some other settings)...Afinia printed perfectly (Normal speed, .15 layer height, dense fill).
photo 3.jpg (244.83 KiB) Viewed 5571 times
Top view (perfect, no sagging that I can see...even in the whistle opening)
photo 2.jpg (127.55 KiB) Viewed 5571 times
Bottom view (part that was touching raft)
photo 1.JPG (241.33 KiB) Viewed 5572 times
amd-tec
Post by amd-tec » Fri Aug 02, 2013 6:28 am
Forget the previuos..., I was looking from the wrong folder.
