partial print then air print issue
Posted: Fri Nov 06, 2015 6:41 am
by okhrana
Ive had my up box for about a week now, I've completed 2 smaller prints and one larger 18 hour print before I started to run into problems. I loaded up another 18 hour print and it started fine. About two hours into the print it began to air print and no more filament was passing through the nozzle. I cancelled the print and cleaned out the extruder and nozzle. Ive also cleaned the gear with some acetone and a metal bristled brush.
I set up the print again and it begun like before, but soon was back to air printing. If i pause the print job I can extrude the filament perfectly.
Im really confused as to why it can extrude without hassle but doesnt complete the print. Am I doing something wrong or missing a step in the printing process? Any help would be appreciated.
Re: partial print then air print issue
Posted: Fri Nov 06, 2015 5:48 pm
by pleppik
1) What kind of filament are you using, and where did you get it? Some third-party filament doesn't perform well or may even contain impurities that can clog the nozzle (though this is a lot less of a problem than it used to be).
2) What kind of environment is your printer in? ABS likes to attract dust particles in the air through static electricity, and these get stuck in the nozzle and clog it. It's a good idea to run the filament through a piece of foam sponge to clean it before it goes into the printer's filament path.
Posted: Sat Nov 07, 2015 4:27 am
by okhrana
Im using a 500gm spool of the UP abs filament that came with the printer.
After reading your reply I added some soft foam to collect any static or dust but it did not solve the issue =/
Posted: Mon Nov 09, 2015 12:54 am
by pleppik
Did you clean out the nozzle with acetone after the clogs? If not, soak it in acetone overnight and use a very thin tool (like a sewing needle) to clean as much stuff out of the nozzle as you can.
The next thing I would check is whether the filament can get pulled into the feeder with minimal friction, or whether it might be sticking or binding somewhere.
Posted: Tue Nov 10, 2015 5:11 am
by KiwiEv
Hi Ok,
I've had my new UPBOX for a few weeks too. Ran into the same problem as you. Running V2.17 and the Box came with the latest extruder shroud (filament drops straight down into extruder). My earlier UpBox has a nozzle height around 206.*. This new one auto calibrated at 209.* They look the same but have different characteristics. Nothing is equal in this world.
Anyway I found by backing off the nozzle height by 0.2 (it's 208 point something now) in software solved the issue. Maybe your nozzle is printing too close to the perfboard like mine was? Anyway my 2c worth. Cheers.
Posted: Tue Nov 10, 2015 8:35 pm
by okhrana
KiwiEv wrote:Hi Ok,
This solved it! I ended up manually calibrating with a piece of paper and it works fine. I had one air print lat night but I think that is just the gear that needs cleaning at it finished 60% of the print before it stopped extruding. Thanks for the advice guys!
Posted: Sun Nov 15, 2015 6:32 am
by okhrana
So I thought manually calibrating my nozzle had fixed the issues I was having. I got one good print out of my UP Box since I calibrated it. Now I'm back to getting partial prints then air print for the rest. The nozzle, extruder and gear are all perfectly clean when I begin the print. The nozzle begins the air print and I perform a withdraw, the filament has gear marks in it and a strange chunk taken out of the top section of it, however there is no sound of clicking as it continues with the air print.
I'm trying to work out if this issue is related to the nozzle and extruder, and if so what the issue is, or if there is some other underlying issue which im overlooking.I dont think the issue is with nozzle height as it begins to print the model evenly and often gets about 80% of it complete before failing. I did look at the bearing on the gear motor that helps feed the filament into the extruder, however it looks quite clean and there is no sign of damage or dust.
I've had this printer a little over three weeks now and I've had more failed prints than successful ones. I'm really starting to regret this purchase =/
Posted: Wed Nov 18, 2015 9:38 pm
by pleppik
okhrana wrote:So I thought manually calibrating my nozzle had fixed the issues I was having. I got one good print out of my UP Box since I calibrated it. Now I'm back to getting partial prints then air print for the rest. The nozzle, extruder and gear are all perfectly clean when I begin the print. The nozzle begins the air print and I perform a withdraw, the filament has gear marks in it and a strange chunk taken out of the top section of it, however there is no sound of clicking as it continues with the air print.
If you're getting at least the first few layers before the print stops you can rule out any problems with the bed height or leveling. Those will cause problems only on the first layer or three.
There are a number of things which can cause the problems you're having. It's best to try to eliminate them one by one until you find the problem:
  • Nozzle is contaminated with dirt or dust. Can be solved with a careful cleaning or replacing the nozzle.
  • Filament is too large and jamming in the front end. Measure the filament diameter with a digital caliper and make sure it's not larger than 1.80mm. Feel along the filament for any bumps. Try a different roll of filament.
  • Filament has dust on the outside which is clogging the nozzle. Pass the filament through a sponge just before it goes into the feed mechanism to wipe off dust (also, give the nozzle a good cleaning).
  • Filament is contaminated with foreign material in the plastic itself. This rarely happens but has been known to be an occasional problem. Get a different roll of filament and clean your nozzle.
  • Too much back-force on the filament path. Check for binding by pulling filament by hand, it should pull smoothly. If it binds or catches at all, this is a manufacturing defect and should be covered by warranty.
  • Excessive heat buildup in the cool side of the extruder is causing filament to soften in the feed gear. This happens most often with PLA, but If your hot end isn't put together properly (heatsink missing or out of place, fan not working right, etc.) it could happen with ABS, too. If you're an expert user you can easily take apart and reassemble your extruder, but as a novice you probably don't want to do this. This is a manufacturing defect and would be covered under warranty.
  • Not enough clamping force between the feed gear and the bearing to properly grip the filament. If this component is out of spec it could cause filament to strip rather than feed; this would be a manufacturing defect and covered under warranty.
I'd contact support and see if they have other ideas. If you can eliminate the filament and environment related problems, then chances are you have a defective extruder and they should be able to swap it out for you.
Posted: Fri Nov 20, 2015 9:39 am
by okhrana
Thanks for your advice.
I tried changing nozzles and cleaning my filament etc as you advised, however I honestly believe this issue is to do with the clamping force of the gear and bearing not being able to grip the filament adequately. I've stripped this extruder down about 30 times in the past few weeks, its become second nature on how to do it now, the heat sinks and and fan are all seated and working correctly. I think i need to contact support for this one =[
Posted: Fri Nov 20, 2015 1:41 pm
by pp3dp.nl
It would be a coincidence but you never know: I had air printing because of the rainbow cable on the print head. After initializing the room temp of the nozzle was too high (like 45 degrees in stead of 21) so ABS would be extruded too cold. Also the temp varied when printing because of this.
So could you check with a cold machine what the temp is? And wiggle/push the cable a bit to see if it changes?
Posted: Mon Nov 23, 2015 2:33 am
by m_bergman
I recently had my Box suddenly stop extruding altogether. Support immediately told me to disassemble the head and check the end of the big white ribbon cable and check for a squash mark. Sure enough it was there, and caused two tracks in the cable to just touch. A manufacturing defect, by the look of it. One replacement cable later, machine works fine and has since done multiple 13 hr prints without difficulty.
I suspect this is also your problem.
As a side note, do several extrudes after changing spools to ensure the spool is turning freely - sometimes it seems to stick, with similar results. Once it's going, it seems to be all good.
Posted: Mon Nov 23, 2015 9:19 am
by okhrana
Ok guys ive checked my rainbow cable and the white one and they both appear to be in tact. I put a brand new roll in and did a few extrudes, they seemed Smooth and consistent so i set up the same print I've been trying for the last two weeks, this time the rafting didn't even print. Im really thinking it is the gear on the motor.
Thanks so much for your advice though.
Posted: Tue Nov 24, 2015 11:57 am
by steelmans
okhrana wrote:Ive had my up box for about a week now, I've completed 2 smaller prints and one larger 18 hour print before I started to run into problems. I loaded up another 18 hour print and it started fine. About two hours into the print it began to air print and no more filament was passing through the nozzle. I cancelled the print and cleaned out the extruder and nozzle. Ive also cleaned the gear with some acetone and a metal bristled brush.
Hi Okhrana, I had a similar problem and tried everything. Sorry that I haven't read this entire post but have you changed the nozzle for a new one? I kept cleaning them out and although it purged ok the problem persisted. I then put on a new nozzle and not had that problem since.
Posted: Sat Nov 28, 2015 6:45 am
by Tiertime-Jason
Please contact support, if this is a defective machine, I think they will be happy to send you a new one.
Posted: Mon Dec 07, 2015 7:27 am
by car3less
Tiertime-Jason wrote:Please contact support, if this is a defective machine, I think they will be happy to send you a new one.
Really? On what planet? Because I would go there.
I received my Up Box in May. And since then it's been a disaster.
First, after only a week - 7 hour print. Stopped mid print and was printing in the air. My colleague tried to clean the nozzle and the nozzle was so weak it was broken.
I contact the supplier and they said I have to send the broken part back to get a new one. Which means time.. and my clients don't give me this time.
So I put the heater assembly in the garbage and bought a new one on my money.
After a while, nozzle overheat errors - stopped in the middle of the prints. Again.
I discussed with the support, followed the steps, But when one error is fixed another one appears. Until yesterday it printed according to its mood. One print ok for 2 or 3 failures.
Since yesterday, the nozzle is not heating anymore (37 degrees).
And I am really tired of this problems. No one replaced any defective machine. Just sending ribbons and giving us basic advice (for 7 months now).
I will pack Christmas presents with your ribbons. :D
Posted: Mon Dec 07, 2015 8:56 am
by steelmans
I'm surprised that you haven't came to a solution yet. Although sometimes frustrating, I found UP support to work really hard to find solutions.
Posted: Mon Dec 07, 2015 10:02 am
by pp3dp.nl
@car3less:
Maybe try to contact TierTime directly, I don't know if you have done that or only the Romanian reseller.. New Up Boxes should be better, they get updated all the time as have the Up Plus and Mini.
I too have had some struggles but mainly I have had a wonderful machine for some months now. When it works it really works well, I hope they can help you get a good machine you paid for and deserve.
Posted: Thu Dec 10, 2015 4:00 pm
by Tiertime-Joseph
Hello Car3less,
Please send an email to support@pp3dp.com, and our technical team will help you out. If you have already done that, please let me know the issues that you have. My email is joseph.guo@pp3dp.com.
Joseph
Posted: Sun Mar 04, 2018 9:31 pm
by tibo
hello
i have the same problem with my UPBOX+
the post is old
but i want' to kwon if you have solve your problem and if Tiertime has help you
i don't know what to do : i have tested all the solution wich was write on this post
i need to print with my student and the printer don't wan't to print 100% with ABS
no problem with the first layer, but always come the problem after ...
thank's for your HELP!
Tibo
Posted: Sat Sep 07, 2019 4:35 pm
by omsgregg
SOLVED! Finally, after years of battling this issue with my own UP Box machines *and* another 10 that I purchased for my university, I finally arrived at the root cause of this nagging problem.
For anyone who has torn into the bowels of this style print head they know that unlike most other commercial extruders that the UP units don't have a spring loaded roller that properly tensions the filament against the splined motor drive unit.
Instead, UP chose to go the cheap route with a fixed bearing that pinches the filament for traction. Herein lies the problem: That preset distance has zero compensation for filament diameter variability and if the filament runs the VERY SLIGHTEST undersize, there is not enough force to drive it against the motor spline which causes it to loose traction and quickly what gear contact it does have it grinds a *smile* into the filament leaving the motor turning and the residual downstream filament burning up inside the hot end.
Further exacerbating this, UP uses a cheap bearing whose inner races wear out quickly creating significantly more slop and effectively reducing the bearing's effective O.D. and of course reducing the pitching traction power to the point that very few parts finish.
I discovered this root cause upon close inspection of the head assembly during which time I used an X-acto knif to pop the 7 mm bearing off its nylon post. What I found was a pile of bearing guts debris trapped behind the bearing. This had alluded me for years! Sure enough, the inner and out bear races had at least 10 mil of slop. ARGH!
Knowing the problem was the first step in solving the issue. To test my hypothesis, I machined a mock bearing out of brass. Just a metal donut of sorts with no bearing races. I cut the OD to 0.312" (5/16") as compared to the stock bearing OD of 0.275" (7 mm). This provided a ran additional radius increase of 0.016" and all of that went into extra squeezing of the filament against the splined drive shaft.
Since my test fix was a bushing and not a true bearing, I just squeezed a dollop of grease to reduce rolling friction and wearing out of the nylon bearing post (shaft).
To my delight, my UP is happily squirting filament all day and all night without issue!!!!
For those of you who ask why this issue of air printing only occurs mid print and not from the get-go, my best hypothesis is that as the head unit heats up, so does the upstream filament (pre heated extruder tube). Thus the filament in the region of the geared drive spline and squeezer bearing is much softer and strips on the gears more easily.
Knowing most readers here aren't machinists or mechanical engineers like me who can fab their own bearing from scratch, I do have a retrofit fix that y'all can do yourselves without much trouble...
I grabbed a piece of friction tape (think skateboard deck stuff) and cut a tiny strip the width of the bearing and , to the best of your ability, as long as the circumference of the bearing (7 mm * pi to be exact). Peel the backing off and wrap it around the bearing's OD. Be careful so as not to have cut it to wide so it doesn't drag against the nylon housing. This effectively will increase the bearing's diameter to 5/16" and restore the pinching power. Notice you may need to use an X-acto blade to shave just a hair off the housing if your newly enlarged bearing OD rubs against the nylon housing. It's easy to check and fix if you detect interference.
This doesn't correct the fundamental design flaw made by the Tiertime designers who should have built in a spring tensioner. But it should get you going again nevertheless.
I am pondering a more elegant retrofit tensioning fix, but in the mean time if you have questions or need pics to clarify this ridiculously long post, you may email me direct at omsgregg@gmail.com.
Good luck and hope this helps at least a few of you!
Also, please forgive the myriad of typos. This was written on my iPhone with a dinky text typing window that wouldn't scroll:-)
