Printed Autopilot case
talk about anything
Locked
svid123
Post by svid123 » Sun Apr 22, 2012 7:33 am
The images of printed case for PCB of my Autopilot project with Up 3d printer.
The dimensions of case are 4x8x1 cm, minimum wall thickness used is 1 mm. Layer thickness 0.2 mm (took at about 1 hour to print case and cap both at once).
Both PCB and case were designed to fit eachother.
Marcus
Re: Printed Autopilot case
Post by Marcus » Sun Apr 22, 2012 9:10 am
Very nice and neat detail work.
woofy
Post by woofy » Sun Apr 22, 2012 10:10 am
Excellent work, very impressive.
josejuako
Post by josejuako » Sun Apr 22, 2012 5:58 pm
Nice box , congratulation .
J
iomega
Post by iomega » Tue Apr 24, 2012 5:55 pm
Looks very nice! Is the labeling printed on a sheet of transparency? And then just glued to the cap?
I've also read about some toner-transfer methods to ABS that seemed to have worked well. You may be interested in that for future projects.
svid123
Post by svid123 » Thu Apr 26, 2012 8:38 pm
iomega wrote:Looks very nice! Is the labeling printed on a sheet of transparency? And then just glued to the cap?
It's self-adhesive transparent laser printer film. Actually I'm more than satisfied with the detail quality & accuracy of print. Almost commercial quality of box. It was very easy to remove supports and raft.
What's the toner-transfer method?
iomega
Post by iomega » Thu Apr 26, 2012 10:06 pm
svid123 wrote: It's self-adhesive transparent laser printer film. Actually I'm more than satisfied with the detail quality & accuracy of print. Almost commercial quality of box. It was very easy to remove supports and raft.
The toner transfer method allows you to print text/graphics with a laser printer and then transfer that pattern by effectively melting the toner onto the new surface (using a hot iron). An example of it being performed on ABS is at this website: http://www.electrobob.com/toner-transfer-to-abs/
rachard1583
Post by rachard1583 » Sun Apr 29, 2012 12:54 am
In a nutshell, this is a form of manufacturing that can create products out of a wide variety of materials in almost any shape and out of a wide variety of materials.
---- SPAM ALERT --------
Locked
