Small nuts and bolts
Lawrence
Post by Lawrence » Sun May 12, 2013 5:29 am
Hi all
A few days ago some one on the forum asked about small nuts and bolts.
So, here are a few:
Small bolts2.jpg (139.27 KiB) Viewed 11961 times
From the left, the 1st is a purchased 3mm diameter nylon nut and bolt. Next is a printed 2.75mm diameter set, then a 2.5mm set and on the right is a 2.25mm set. All nuts do screw on to the bolt securely. The images are taken with the raft removed but no clean up of the models done.
To show the sizes of the three printed sets I have added them with the measurement caliper which unfortunately the camera could not capture the reading which was 2.25mm.
The ruler measurement gives some idea of sizes:
Small bolts.jpg (90.85 KiB) Viewed 11961 times
So, in answer to the query about the Up!Plus having the ability to print small nuts and bolts, it's a definite YES!
Lawrence
Re: Small nuts and bolts
Post by roller » Sun May 12, 2013 2:29 pm
You're nuts...
and bolts too i guess
scubamatt41
Post by scubamatt41 » Sun May 12, 2013 3:26 pm
Yeah, Lawence is Bolts ;) and really small nuts :lol:
Lawrence
Post by Lawrence » Mon May 13, 2013 7:05 am
Hi again
... even smaller now. Today I printed the same nut and bolt, but this time with a 2.00mm diameter. So, yes, the Up! will successfully print useable M2 nuts and bolts.
I won't bother uploading a photo. Just look at the previous ones that I posted, then step back further from your monitor until they look smaller. That is what the M2 nut and bolt look like.
I must bolt now.
Lawrence
Post by roller » Mon May 13, 2013 7:07 am
They are very impressive. Have you just used a thingiverse type source or did you draw these up yourself?
Lawrence
Post by Lawrence » Mon May 13, 2013 7:11 am
Hi Matt
I downloaded some nuts and bolts from Thingiverse, then imported the ones I wanted use into Google Sketchup, where I modified the bolt head to a knurled circle and added a groove for a screw driver, then converted it back to STL format. The rest is history.
Lawrence
scubamatt41
Post by scubamatt41 » Mon May 13, 2013 2:31 pm
Nice work Lawrence :)
josejuako
Post by josejuako » Tue May 14, 2013 4:20 am
Yes Lawrence , very nice work .
outsider
Post by outsider » Thu May 16, 2013 11:33 am
Lawrence,
What print settings did you use to print those nuts and bolts?
What was the material?
adrian.
My Blog
Lawrence
Post by Lawrence » Thu May 16, 2013 11:51 am
Hi
all explained here: http://www.pp3dp.com/forum/viewtopic.ph ... =60#p16834
Lawrence
