Downgrade to Studio 2.4?
Mort
Post by Mort » Sat Feb 02, 2019 10:45 am
Is there a way to download and downgrade to Up Studio 2.4?
Since the recent update, my Up mini stops printing after a while (sometimes it doesn't even start, usually after about 10-20 minutes), often I even need to disassemble the extruder to remove stuck filament. Extruding works fine, but it seems like the temperature isn't kept stable properly. I even tried with three different filaments (PLA, ABS, ABS+), same issue with all of them. Never had any troubles with the old versions.
TiertimeBrook
Re: Downgrade to Studio 2.4?
Post by TiertimeBrook » Mon Feb 18, 2019 12:34 am
Hello
From this article you can find the download link .
https://support.tiertime.com/hc/en-us/a ... tivate-it-
Brook
steverogger007
Post by steverogger007 » Wed Mar 06, 2019 6:28 am
I tried hard but due to the wifi issue, I cannot download it. I am repeatedly getting connection failed with error 651 after the installation of the software. I dont know the reason behind it so please help me to solve it.
Tiertime_Ocean
Post by Tiertime_Ocean » Wed Mar 06, 2019 6:49 am
Dear Customer,
Please connect 3D printer to 3 grid signal router and then connect the computer to this router.
Open UP Studio and you can connect computer to 3D printer via WiFi.
Please place 3D printer near router if you can't search 3 grid signal WiFi.
And also you can connect 3D printer to router via internet cable if the device have network port and computer connect this router via WiFi.
