UP BOX+ Temperature Readings
hybridhuman69
Post by hybridhuman69 » Fri Dec 01, 2017 2:15 pm
Hi Guys,
We have literally just unboxed our new UP BOX+ printer and set a test print going.
Can I just ask, is the tempertaure readings correct (see attached picture). Should the extruder and bed temps be running at nearly 100% ???
I'm trying to find in the literature whether that's what they're supposed to be at, or whether the readings are false?!
Thanks for any advice
J
Re: UP BOX+ Temperature Readings
Post by Owen Sparks aka Marksman » Mon Dec 04, 2017 3:54 pm
Hi.
It's indicating 100% of the target temp, not of the maximum the machine can run.
So if the material is set to 275 deg and it's at ecactly 275 then it'll show 100%. Or if the target is 200deg. and it's at 202 deg then it'll show 101%
So all is good with your printer :D
