PETG-Carbon / GCODE / Raftless / Zero Warp
Post by Owen Sparks aka Marksman » Sat Oct 21, 2017 10:42 am
Hi folks.
Thought this might be of interest.
We make mostly jigs and fixtures for work and invested in UPBOX machines so we could print in ABS. (Strong, can be drilled and tapped etc, but at the risk of warping.)
Despite designing with ABS in mind, heated beds etc we've had good and bad results with ABS. Some great, some welded to the raft, some warped etc.
So I'm experimenting.
In this thread I proposed some hardened nozzles so we can print the abrasive filaments. https://www.up3d.com/community/viewtopi ... 23&t=56015
So I finally got round to testing some Carbon Loaded PETG and the results were surprising.
Now it likes lower temps than ABS (for both nozzle and bed) so I thought lets throw everything at it at once. We have new material, printed raftless on a smooth build plate, using GCODE via S3D, and it's the entire width of the UPBOX build plate. What could possibly go wrong? :P
As it turns out, erm, nothing went wrong.
PETG_Carbon 1st Print.jpg (1.16 MiB) Viewed 9036 times
Here is the same part printed in ABS with fully heated bed...
ABS Comparison.jpg (982.92 KiB) Viewed 9036 times
The PETG-C popped off the bed and looks nice. Many materials claim to have no warping just as all printers advertise a large print volume. What I saw here wasn't less warping, or minimal warping but zero warping. None, nada, ZIP. :D
It also costs the same as ABS+
If folks are interested I'll do some more testing.
I'd love to try this with the new UPBOX glass bed...
Last edited by Owen Sparks aka Marksman on Wed Nov 29, 2017 4:24 pm, edited 1 time in total.
vmstech
Re: PETG-Carbon / GCODE / Raftless / Zero Warp
Post by vmstech » Thu Oct 26, 2017 1:06 pm
Wow, I'm impressed!!
A couple of questions:
1) Was this using the standard nozzle or a hardened one?
2) Where did you buy it from? Looks like it's worth giving it a try.
Let us know if you continue to have success with it or if over time you come across issues.
Post by Owen Sparks aka Marksman » Thu Oct 26, 2017 2:00 pm
Hi VMS, good to hear from you ;)
vmstech wrote:Wow, I'm impressed!! Heather
Groovy, glad to hear it.
vmstech wrote: A couple of questions:
Heather
For this print I sacrificed a virgin. (New UP standard 0.4 brass nozzle, the other kind is hard to find in these parts.)
Heather
More info here:-
Owen S,
vmstech
Post by vmstech » Thu Oct 26, 2017 3:21 pm
Great cheers. Keep us updated on developments :D
tel
Post by tel » Fri Oct 27, 2017 6:22 am
Owen
Would also be interested in what settings you have in S3D to achieve the results.
Post by Owen Sparks aka Marksman » Fri Oct 27, 2017 11:28 am
tegregg wrote:Owen
No worries, I'll post the profile next week.
O.S.
Robin
Post by Robin » Mon Nov 20, 2017 11:02 am
Looks good to me, I just ordered a kg to play with :mrgreen:
If it does stick to glass that would be fan dabby dozie.
I am currently smearing Pritt over Pyrex, baking it on then an ABS/acetone wash to make it stick. I feel a bit like an alchemist questing for the philosopher's stone.
I use AliExpress, brass, 8mm nozzles, £4.07 for 5 pcs. They come threaded M6x1 but I have an M6x0.75 tap with the end ground flat that sorts them out. Works a treat, no leaks at all. At less than £1 a pop I don't mind throwing a few away.
Post by Owen Sparks aka Marksman » Wed Nov 29, 2017 4:23 pm
Hi Pobin.
God stuff, please let us know how you get on with it.
Robin
Post by Robin » Sat Feb 10, 2018 10:39 am
Does not want to stick to the build plate. Very inclined to block the nozzle.
They do suggest a 0.5mm steel nozzle so maybe my 0.4mm brass was not up to it.
I get the impression the bod selling it on ebay had much the same problems which is why he was unloading it.
