UPStudio Change Log
Tiertime_Betty
UPStudio Change Log
Post by Tiertime_Betty » Fri Mar 10, 2017 3:28 pm
2.2.37.62
What’s New?
1. Added Supports Editor
You can edit support and overhang structures in UP Studio.
Also, provide three different display options to view the structure while editing.
2. Added layer preview in Preview.
Layer preview: include supports, layers, and infill structures. Also can play the to animation actual printing process.
Preview also available to view as lines with the linear view.
3. Print bed turns to transparent if viewing in Down angle.
4. Default color of the model change into gray.
[b]UPStudio V2.1.0.8Beta:[/b]
1. Added rotate and move function in the Clip View.
2. Added display progress bar at the bottom with cancel button while loading 3D model.
3. Added animation to the Manual Calibration.
4. Added Printer’s QR code
Where to find: Login -> My Account -> My 3D Printer -> Generate connected printer’s unique QR Code
You can save this QR Code to your computer.
How to use: Open the UP Studio app on your iOS device, and then connect your printer by scanning its QR Code.
5. Added auto-delete update packages.
Fixed and optimised:
1. Fixed printing issues with G-code file.
2. Optimised Moshop’s function and display.
3. Optimised drag and drop function of Wheel menu.
4. Optimised Clip View.
5. Optimised Rotate Face to Bottom in the Rotate.
upstudio v2.0.2
Improvements:
1. Increase error prompts in vertical calibration xy and xz.
2. Optimized dialog box display in program.
3. Optimized judgment for vacant slot position; For baseplate which do not change nozzle height, the slot will not be cleared if choosing that option.
4. Optimized the display of absorption when round plate moves to edge.
5. Increase progress bar when loading gcode.
6. Optimized Balloon ToolTips of button.
7. add GCode tutorial in page “Help”
Fixed bugs:
1. Fixed bug with wifi disconnection when printing large model.
2. Fixed bug with error prompts in mouse pointer when dragging round plate.
upstudio v2.0.1beta
fixed:
1. Fixed refresh Printer List at Top Menu Bar.
2. Fixed tilted model display after Upload.
3. Fixed issue causing model display
4. Fixed cannot undo after “Save” the model.
5. Optimized the size of coordinate.
6. Fixed issue causing white screen.
7. Optimized cursor performance.
8. Fixed issues with disappearing frame of build envelope.
9. Fixed garbled text in “Font” function.
10. Fixed Reset function after model been Flip.
11. Optimized Clip View.
12. Optimized coordinate operations in Roate.
13. Fixed "Preheat" cannot save in Printer Settings.
14. Optimized build envelops dragging performant by hold right-click.
15. Fixed issue causing build envelops cannot be dragged.
16. Fixed software crashing if printer connected via USB cable.
17. Optimized XYZ Axial Calibration.
18. Fixed auto Login interpreted by slow internet connections.
Optimized:
1. The wheel menu can be docked as a left, top or right menu by dragging at the wheel’s edge or center UP logo.
2. Optimized default view direction of Clip View.
3. Increased the largest Scale selection from 3 to 10.
4. Optimized printer data display.
5. Changed the location of Mac address--move out from internet info to printer info
6. Added warning before running G-code.
upstduio v2.0.0beta
1. Optimized Wheel Menu:
a. The edge of the Wheel Menu can be dragged and dropped to become a left, top or right menu bar.
b. The Wheel Menu cannot be dragged during 2D image editing.
c. Wheel Menu positioning is remembered between UP Studio usage sessions.
2. New Wheel Menu functions:
a. Display Model: Wireframe, Solid and Wireframe, Transparent and Solid.
b. Flip: Convert the model to its mirror opposite on a chosen axis.
c. Clip View: View the model’s interior using a sliding axis plane.
d. Rotate Face to Bottom: Automatically rotate the model so a selected face becomes the bottom.
e. Drop to Print Bed: Drop the model to the print bed.
3. New Add options:
a. More file formats: obj,3mf,ply,off,3ds,gcode.
b. New Basic Models: Pyramid, Tube, Wedge, Right-Angle Wedge, Star, Font.
4. Right-Click Model Menu:
a. Now Edit Basic option (opens a window for editing basic UP Studio models).
b. New Voxelization option (represent the model as cubes).
5. New Anti-Crash feature.
6. New Feedback Section.
7. Undo maximum increased from 10 to 20 steps.
8. Zoom centered on cursor by mouse scroll wheel.
9. Optimized the process of model upload.
10. Print Settings Preferences button replaced by double-right arrow in Print Settings title bar.
11. Optimized Top Menu Bar:
a. Should not disappear anymore.
b. Click the printer’s name to connect to another printer.
c. Added animation for filament icon.
12. Double-click the left mouse button to reset Zoom level.
13. New Stop Preheat function.
14. Optimized content popup window for software upgrade.
15. Optimized model download at Moshop.
16. Added UP Glass Board as default print board type for UP BOX and UP BOX+.
17. Altering nozzle height will now delete all saved print slot content. Actions such as Auto Level, Nozzle Detect, software-assisted manual calibration and changing the Print Board type will alter the nozzle height. Therefore, after performing one of these actions, all saved model print slots will be
UPStudio v1.9.2.2 released
1、 solved problem of UPStudio can't install on windows 10 OS
2、optimized moshop
UPStudio v1.9.1 released
1.Optimised text setting for editing 2D image.
2. Remove the model size limitation for editing 2D image.
3. Added radius setting for scaling “Torus.”
4. Optimised “Align to the floor.”
5. Optimised model display.
6. Optimised banner display.
7. Optimised model arrange meant for copying model.
8. Attached calibration model for vertical calibration.
9. Optimised “Normal Link” as default for network settings.
10.Bug fixes and performance improvements .
11.Added login forbidden.
UPStudio v1.9.03 beta
1、UP页面右下角增加六视图(以模型为中心),与圆盘的六视图的区别是:圆盘上是以全局为基准的视图变换,新增的目的是看清模型,以模型为专注点;
1. Added "Control Cube" at the right bottom corner of build envelop which allows you to view the model with specific directional attributes.
2、圆盘中将“删除”替换成“对齐到底板”:单击拾取一个平面,将此平面放置到底板上;
2. Replaced “Delete” with “Align to the floor” at wheel menu. Click the certain plane to place the model on the backplane.
3、增加框选模型:通过按住鼠标中键框选;
3. Added group models selection while holding middle button on mouse.
4、在模型的旋转环上增加指示方向的箭头;
4. Added directional arrows on operate axis rotating the model.
5、增加删除模型可以回退:回退最多允许10步;
5. Added undo "Delete Model". Maximum 10 steps backwards can be undone.
6、网络连接中的普通连接增加设置本地代理的功能;
6. Added “HTTPS Proxy” option if “Normal Link” selected. This option only available to select if the button highlighted.
7、在打印--高级打印里面增加“轮廓线宽”的设置,设置逻辑为:
1) 选择范围为默认轮廓线宽的 -0.15 到 +0.25mm, 但不能小于默认线宽的0.7倍。
2) 已0.05mm为间隔,预设选项,供用户选择,也接受用户自己输入,但限制范围。
例如: 0.2层厚默认0.47mm轮廓线宽, 则选项为0.32,0.37,0.42 ,0.47,0.52,0.57,0.62,0.67,0.72。
用户的输入范围为0.32~0.72,两位数精度。
7. Added "Contour Line Width" editing section in "Advanced Print."
8、增加本地模型库(以账户来分的),原有的模型库中,只有精品模型;
8. Only featured mode displayed in Library. Moved “Local” and other categories to “My Account”.
9、右键属性增加对基础模型的参数设置,且属性页面可允许拖动;
9. Added "Model Attributes" section in “Property” in right-click menu. And the “Model Attributes” window can be dragged around.
10、优化添加图片中的添加文字功能;
10. Improved "Text" feature in 2D Image setting.
11、添加图片中增加转换基底(增加了灯罩和相框),去掉了橡皮:暂时将风格替换成转换基底11. Added "Select Base" (Lampshade and Frame )in 2D image setting.
12、校准界面喷嘴高度数值可实时跟着喷嘴移动变换;
12. Value in Nozzle height box change along with actual nozzle height moved.
13、优化添加图片中模型尺寸的功能:可解锁,点击“对称”可转换实际尺寸;
13. Improved "Model size" editing.
15、优化ip连接打印机的ip输入:一上来就可以看到鼠标闪烁,可以按tab键跳入下一个位置;
15. Improved entering IP address: visible mouse flickering and click “Tab” start entering at next edit box.
16、自动校准和自动调平后将底板选择加回来
16. Brought back "Platform" option at the end of the auto level, and nozzle detect process.
UPStudio v1.8.1.0
Fixed:
1. Fixed jog system error
2. closed check material function without connecting printer
3. Fixed the bug of internet out of time while print and reprint
4. Fixed the bug of "Login button"cann't be clicked while login out of time
5. Fixed the bug of" The online printer always rember the information of previous one"
6. Fixed the bug of "the mask of UI will not disappear whiel Fixed small model finished "
7. other UI bugs
Update:
1. the offset value of nozzle height will not be clear after nozzle height detect
2. 100 extra porints will be got after active a printer
UPStudio v1.8.03 beta release
1. Upgraded Calibration Module to Model Calibration, and offered Calibration STL downloadable from website.
2. You can connect to a printer with entering its IP address.
3. You can connect to a hidden WIFI by entering SSID.
4. Added Text support on Image. Text can be moved around, and new line is supported.
5. Moved Platform Setting from Auto Height Adjustment and Leveling to Maintenance Dialog. The Platform parameters will be obtained from the server.
6. Added “Print Time Remain” in Model Library
7. Added software declaration
8. Added “Settings in the Cloud”. You can use the best printing parameters in the Cloud.
Improvements and Fixed bugs
1. Improved when copying models
2. Added animated icons when increasing or reducing temperature of nozzles and built plate.
3. Optimized the scroll bars for the pull-down frame.
4. Support ultra-wide screen.
5. Fixed bug when determine if a model is out of print area. The nozzle height adds the height of the raft and the compensation offset.
6. Optimized the print path algorithm: Only when using Perf Board printing with raft, the printing path engine will avoid certain areas on the build plate. (For UP BOX, and UP BOX+ only.)
7. Added better error messages indicating which axis is at fault when “Motion Systems Error” occurs.
8. The nozzle’s offset value will clear once printer’s nozzle height change.
UPStudio v1.7.3 Release:
1、Change the relationship between nozzle and layer thick:
0.2mm nozzle~~~ 0.15mm or lower layer
0.4mm nozzle~~~~0.1~0.35mm layer
0.6mm nozzle~~~~0.3~0.4mm layer
2、Optimized the print quality while choosed 0.2mm nozzle
3、Fixed serials of bugs of UI
UPStudio v1.7.2 Release:
1、 Fixed page bug while using Russian
2、 Fixed a bug that UPStudio crash while delete and add a model at the same time.
3、 Only UP BOX and UP BOX+ can change nozzle, and the relationship of nozzle diameter and layer thick is:
0.2mm nozzle~~~ 0.15mm or lower layer。
0.4mm nozzle~~~~0.15~0.35mm layer。
0.6mm nozzle~~~~0.3~0.4mm layer。
4、 Fixed the bug while using 0.2mm nozzle, nozzle extrude too much material.
UPStudio v1.7.1.0 beta
New Function:
1. Can change printer nozzle in maintanece page.
2. Can choose internet connection way between https and socket
Optimized:
1. Copy models: UPStudio will initial view after copying, and selected the last model instead of selecting all of copied models like old version.
2. Door detected: It will stop data tranfer if the printer has been unconnected instead of displaying a error message
Fixed:
1. fixed the bug of cann't picked the model operating shaft
2. fixed the bug of win7 x64 crashed
3. fixed the bug of user interface error when model data transfering
UPStudio v1.7.0.6 beta
1、Speed up moshop
2、Optimized the user login system, make it be more quick and stable;
3、Give a hint while cloud printer parameters have been used.
4、More detailed error hints for slicing;
5、Add the history material weight of printer
6、Add two new languages, Thai and Russian;
7、Fixed the bug for privacy policy setting conflicted
8、Optimized the style of three buttons as "print","reprint",and "print preview"
UPStudio v1.6.12
1 Fixed the bug of “While using the edit box to zoom model ,mouse always jump to the first edit box "
2 Fixed the bug of “It can’t pick the model while open the model through drag way'
3 Fixed the bug of “Image UI turn to white screen while clicked the button “Turn back” "
4 Fixed manual calibration page error of entering horizon calibration page after the manual calibration starting
5 Fixed the bug of the history records have not been saved when PC was out of network.
6 Fixed the bug of “Cann't upload models”
UP studio v1.6.09
New Fuctions:
1. Add "Vertical Calibration" function.
2. Add "Pushing Notification". The urgent messages of TierTime will be passed on to you in time .
3. Add "Manual activation", you can activate printer with a active-code-file while internet is not good enough.
4. Change the icons of main page.
5. Provided there edit boxes under the software, and allow you to scale model to a accurate size.
6. The color of each model can be set separately throght property page("right click menu -- property".
7 .mac(will release later):
1.Can change the size of the window freely
Optimized:
1. Canceled several pop-up dialog like "Initial printer","calibration success",etc
2. Will not changed the rotate center before rotate operation finished while rotate a model
3. If UPStudio is using the cloud parameters print, it will show a "cloud sign” at the bottom of the interface.
4. The price of published model is always 1point.
UP studio v1.5.1.1
Additional function and optimization :
1. Conneting the printer by USB, mac address can be found in the property page.
2. …
3. The problems that support for bottom surface is hard to be remove or bottom surface is rough is optimized.
4. Adding display for Infill (e.g. 99%, 80%, …)
5. The step size for Automatic Nozzle Height Detection is changed from 0.02 to 0.04, so the detection time for this version is about 1 minute less than beta version.
Bug fixes :
1. Fix White screen problem with beta version under AMD HD 5000 or lower video cards.
2. Fix the problem that compsenation values cannot be acquired or values are displayed as zero by wifi connection.
3. Fix the limitation error for adding new customized material.
4. Fix picking up space unreleased problem after printing setting interface is closed.
5. Fix the problem about slot position information not updated from USB to wifi connection.
UP studio v1.5.03
New functions:
1. Add basic models: "Add --infill"
2. add two infill modes: 99% and 1%
3. add "paused at specified layers": Go "print page--advanced print"
4. add "nozzle height" and "height offset" on printer page.
5. add "clear storage" on setting page
6. add manual signed mac app function(Get LDK from website and load in UPStudio)
Fixed:
1. UPStudio(mac) will paused after printing the first layer.
UP studio 1.4.1.3
PC.
1. Added "moshop" ,Tiertime will offer 500M of free cloud storage and 100 points of downloaded models to the registered users.
2、Fixed bug of crash on PC with cpu what doesn't AVX2 instruction sets--E7500,E8500,Q8300,CELERON
3、 Support mac osx 10.12
4. Fixed bug of installing driver failed on win7.
5.Fixed bug of v1.3.2.4 that printer can't be actived
6.Fixed bug that the "turbo" item disappeared while the BOX and BOX+ connected
7 Allow input any character for AP password
8.Optimised software interface.
9. Added prompt dialog box after printing job finished for BOX+ and MINI2
IOS:
1.Optimised software interface. Much more smooth operation in general
2.Add palette for modifying model color.
3.Added "moshop" ,Tiertime will offer 500M of free cloud storage and 100 points of downloaded models to the registered users.
UP studio 1.3.2.3
1 added Korean language
2 added image editing tools for 2D to 3D conversion
3 Optimized display of orientation info of model
4 added individual model info and merge function in right click menu
5 Added animation when switching to different preset perspective
6 fix self destructive bug that auto reprint after finishing a print
7 fixed infill and support angle not response to user setting bug.
UP Studio V 1.2.0(windows)
1. Fixed auto update hanging bug.
2. Added manual leveling step by step guide.
3. Now able to run the program in window (finally
4. Added platform heating option, now user can manually heat up the platform.
5. Added option to allow printer to "sleep" after print finished.
6. Added Japanese language.
7. Now compatible with the latest win10 upgrade.
UP Studio V1.1.2.0 update
1. A new skin and ability to change model color
2. Inlcuded new language support: German, Italian, Traditional Chinese
3. Optimzied the wheel menu, easier to input values.
4. Improved 3D display algo, more smooth operation.
5. Opimized Wi-Fi setting interface.
6. Able to edit machine name on the status bar.
7. Optimized print parameters.
UP Studio V 1.0
Win/Mac:
1.Optimized account related interfaces.
2.Store up to 10 print jobs in the machine for reprint
3.Improved calibration interface
4.Added customized material so user can define nozzle and platform temperatures and able to store up to 4 profiles.
5.Added Preheat function in Preference interface
6.Extrude and Withdraw buttons now have animations to indicate machine status.
7.Download models from the cloud in the Library section.
8.Improved model info display
9.Add WIFI private password setting
10.Much more smooth operation in general, significantly improved performance for complex models.
11. Support Black Out Recovery function in new machines, eg UP mini 2
IOS:
1.Improve registration process
2.Added a pixel base modeling tool
3.Able to use cutomized material profiles.
UP Studio V1.0.0.4 Beta Update
1. Adjusted slicing algorithm to fix print quality problems.
2. Bug fixed - cannot use special characters to sign in inside software.
3. Changed printer default name to its serial number.
Last edited by Tiertime_Betty on Fri Dec 22, 2017 12:57 am, edited 17 times in total.
sn00ze
Re: UPStudio Change Log
Post by sn00ze » Sat Mar 18, 2017 2:33 pm
Thanks for this lbbetty.
Can it be pinned up the top of the board somehow so it doesn't get buried?
JuanCR
Post by JuanCR » Mon Mar 20, 2017 5:08 pm
thanks lbbetty!!
Tiertime_Bryant
Post by Tiertime_Bryant » Mon Apr 24, 2017 5:38 am
So wonderful!
Veryyyyyyyyyyy thank you!
Post by Owen Sparks aka Marksman » Tue Apr 25, 2017 1:48 pm
Just looked for the new download and have seen the latest beta seems older than the release.
Release:- 1.7.2.0
Beta:- 1.7.1
Cheers, Owen S.
JuanCR
Post by JuanCR » Tue Apr 25, 2017 5:01 pm
1.7.2 Studio for windows lower layer is 0.20mm, back to the beta version.
Tiertime_Betty
Post by Tiertime_Betty » Wed Apr 26, 2017 2:06 am
imprenta3d wrote:1.7.2 Studio for windows lower layer is 0.20mm, back to the beta version.
Only UP BOX and UP BOX+ can change nozzle.
JuanCR
Post by JuanCR » Wed Apr 26, 2017 8:23 am
Will give a try then :-)
JuanCR
Post by JuanCR » Wed Apr 26, 2017 8:44 am
Nope, with 0.4mm nozzle you have 0.20->0.35mm layer heigh in an Up Box
0.20-0.35 layer.JPG (52.18 KiB) Viewed 13755 times
carbokart
Post by carbokart » Wed Apr 26, 2017 6:21 pm
How could I know which nozzle I actually have on my printer. I got 2 nozzles with my Upbox+ and both look the same, no punch mark to identify them as a 0.2mm or 0.4mm. If there is a 0.2mm, 0.4mm and 0.6mm on the market, there should be punched with a number on it to easily identify them.
Until I updated the software this morning I was assuming I could select any thickness layer I want without changing nozzle. And now I have to figure out what nozzle size I have on hands but what is the easy way to reconize them, and what are the size of the two nozzles I got with my Upbox+, did I get a 0.2 and a 0.4mm or both are the same size?
I will start by measuring the size of the filament that comes of them so I will know the approximate size but there should have a mark on them of some sort.???
carbokart
Post by carbokart » Thu Apr 27, 2017 1:05 am
So I measured the diameter of the filament that comes out of both my nozzles and they are the same size, both filament measures about 0.45mm so I figured the filament expand a little when it gets out.
Does this mean the printer is sold as a 0.1mm layer thickness but it doesn't do it right out of the box ???
Tiertime_Bryant
Post by Tiertime_Bryant » Thu Apr 27, 2017 3:07 am
carbokart wrote:How could I know which nozzle I actually have on my printer. I got 2 nozzles with my Upbox+ and both look the same, no punch mark to identify them as a 0.2mm or 0.4mm. If there is a 0.2mm, 0.4mm and 0.6mm on the market, there should be punched with a number on it to easily identify them.
The diffience:
If there is no mark,it must be 0.4mm.
carbokart
Post by carbokart » Thu Apr 27, 2017 8:21 pm
Thank you Tiertime_Bryant, your picture says it all and also validate my measurements of the size of filament that comes out of my nozzles.
But what happends with the new software version when I want to print in 0.1mm layer thickness in which I have to select a 0.2mm nozzle even though I have a 0.4mm installed on the printer? Does the new software have changed something more than just visual selection or do I really need a 0.2mm nozzle to do 0.1mm printings now?
Tiertime_Betty
Post by Tiertime_Betty » Fri Apr 28, 2017 1:37 am
carbokart wrote:Thank you Tiertime_Bryant, your picture says it all and also validate my measurements of the size of filament that comes out of my nozzles.
Right, you can select 0.2mm nozzle to do 0.1mm printings even through you installed a 0.4mm on your printer.
Tiertime_Bryant
Post by Tiertime_Bryant » Fri Apr 28, 2017 3:11 am
Thanks so mush for your feedback:
1.If you set 0.2/0.6mm nozzle just in UPStudio,You can get the same print quality as 0.4mm
2.If you change the nozzle to 0.2mm/0.6mm on your printer actually, you will get a better job.
Have a good time!
krisjaniz
Post by krisjaniz » Tue May 02, 2017 12:29 am
Tiertime_Bryant - this software limitation of 0.2 with 0.4mm nozzle seems like a really bad ploy to get us to buy new nozzles.
Previous version worked down to 0.1mm with a 0.4mm nozzle and produced pretty decent results. If I now set a "0.2mm" nozzle in software but actually use a 0.4mm nozzle, my results at 0.1 will be worse than before. This is pure math - the software has to know the correct nozzle size to tell the printer to push the correct amount of filament.
Why this artificial limitation? Why can't we have 0.1mm layer height in software for 0.4mm nozzles as we did before? Of course, results would probably be better with a 0.2mm nozzle. But this is not the way to market this new "feature".
carbokart
Post by carbokart » Thu May 04, 2017 1:15 am
krisjaniz wrote:Previous version worked down to 0.1mm with a 0.4mm nozzle and produced pretty decent results. If I now set a "0.2mm" nozzle in software but actually use a 0.4mm nozzle, my results at 0.1 will be worse than before. This is pure math - the software has to know the correct nozzle size to tell the printer to push the correct amount of filament.
Judging by Tiertime_Bryant's answer to my question about this problem, the software doesn't use the nozzle size information for calculation but only the layer thickness. Having the right nozzle on the printer will only optimized the result that can be obtained for the selected layer thickness.
I think it's for best that the nozzle selection limits the layer thickness selection this way in the software. It serves as a reminder of what you have installed on your printer, otherwise you would have to check go in maintenance menu everytime to ensure you have the right nozzle. But the selected nozzle size should at least appear beside the layer thickness selection, or even be selected there.
tel
Post by tel » Wed May 10, 2017 4:11 am
So when will we see the 0.2 and 0.6 nozzles released? Other than a change in the software the physical nozzles dont seem to exist anywhere
carbokart
Post by carbokart » Wed May 10, 2017 10:12 pm
Software update 1.7.3 is out specifying optimization for 0.2mm and 0.4mm nozzles. Does this mean that I should really install a 0.2mm nozzle for printing 0.1mm layer thickness if I use this new update? Briant told me the nozzle selection has no effect on software calculation, according to this update this is not true anymore. ???
carbokart
Post by carbokart » Wed May 10, 2017 11:44 pm
Sorry for my previous post, I reacted too quickly, we can now select 0.1mm layer thickness even when using a 0.4mm nozzle selection and optimized for the selected nozzle. Great update !!
As an addition, It would have been interesting to have the selected nozzle displayed near the thickness selection as a reminder.
