'Platform Too Hot' error
titaniumapple
Post by titaniumapple » Sat Dec 31, 2016 3:30 pm
Hi, I've had the Up Mini 2 since August and while preheat could be quicker, it has worked well.
Now the temperature of the print bed fluctuates randomly as it is printing - it goes from the normal expected temperature and jumps up extremely high (130+) and back again and then eventually stops printing because it thinks the platform is too hot (but in reality it's a normal temperature) - see attached photo.
I'm guessing it might be the black platform heater cable, possibly the wires inside the cable are worn out? It does a lot of movement during printing as the print bed moves backwards and forwards.
Are there any visual guides for how to replace it?
I've emailed Tiertime and iDig3Dprinting (the UK supplier I bought it from) to get a replacement, hopefully it's resolved quickly because I've got a LOT of urgent printing to do!
titaniumapple
Re: 'Platform Too Hot' error
Post by titaniumapple » Mon Jan 02, 2017 10:10 am
Does anyone know what the black cable connecting to the platform is called? Could I get a replacement from an electronics store? Really need a quick solution!
Post by wackojacko » Mon Jan 02, 2017 7:11 pm
It's an ffc cable but will be tricky to find, to contact your reseller or Tiertime to get a replacement, it might be your motherboard.
titaniumapple
Post by titaniumapple » Wed Jan 04, 2017 9:30 pm
Thanks, it's definitely the ffc cable - the Up Mini 2 has a clip that holds the cable in place - but the sharp edges of the grey clip are wearing away the cable as it goes back and forth during printing and the wires inside are fraying and causing temperature fluctuations (poor design).
See below:
crimped ribbon cable.jpg (1.73 MiB) Viewed 11506 times
I've contacted my reseller for a new cable - but are there any diagrams/videos for how to replace the cable? I can replace the platform end of the cable but don't know where the other side of it goes to (and how to get to it).
Tiertime-Roman
Post by Tiertime-Roman » Thu Jan 05, 2017 7:04 am
Hi Adam, I've given my response via HelpDesk. And we would like to show you the operation to replace the cable. Could you please also check my mail and give your feedback? Best regards!
titaniumapple
Post by titaniumapple » Fri Jan 06, 2017 10:53 am
Roman from support has been excellent and has sent a video of how to replace the cable. Now I just need the cable! Waiting on my reseller to send one...
cales
Post by cales » Mon Oct 30, 2017 7:58 am
Can the video be posted here, or do we have to contact support?
Austo63
Post by Austo63 » Fri Nov 09, 2018 2:00 am
Just wondering how i can get a copy of the video to replace this cable as i have the exact same issue.
Thank you in advance
Ray.
mpopken
Post by mpopken » Thu Nov 15, 2018 8:25 pm
Can we get a copy of the video as well. We have the same problem.
3DWP
Post by 3DWP » Thu Dec 13, 2018 11:59 am
Is this video available somewhere? It would be helpful for everybody who has this problem, I know somebody who has the platform heating error.
3DWP
Post by 3DWP » Fri Dec 14, 2018 5:58 pm
Come on Tiertime, the video isn't a secret is it?
I would like to repair a printer but the video isn't on your Youtube :x
3DWP
Post by 3DWP » Mon Dec 17, 2018 5:13 pm
Well I had to find out for myself.
The platform can be removed by carefully pushing back the pins on the sides (4 of them).
When the platform comes loose you can remove the cable by wiggling the binder connector under the printbed.
The Up Mini 2 I was fixing luckily didn't have a broken flat cable, it turned out it was never connected well from the factory (it had heating problems off and on from the beginning).
When I removed the 3 screws from the motherboard protetcive cover I could see it was not straight in the socket.
