How to print this horse?
junochoi
Post by junochoi » Mon Oct 17, 2016 7:48 am
I have tried to print the horse like the attached image, but the front-right leg of the horse always be broken and i do not know why. I have even changed support option quite many times, but I finally failed to print it.
I will wait for your kind advise how to print that horse.
Thank you.
Tiertime-Jason
Re: How to print this horse?
Post by Tiertime-Jason » Mon Oct 17, 2016 8:12 am
If you are printing ABS, close the fanduct to reduce cooling. Since too much cooling will cause the print to warp and hinder the nozzle.
Marauderz
Post by Marauderz » Mon Oct 17, 2016 2:16 pm
You should show us pictures of the failures so we can see how is it failing, cause there're many ways it can be 'broken'
Tiertime-Roman
Post by Tiertime-Roman » Thu Oct 20, 2016 3:07 pm
Generally when the support angle was set to over 45, this part would be support well, could you please show your setting in software? In addition, please also provide the pictures about the final model as our reference.
