I recently purchased an Up Mini printer with the above order number. It arrived two days ago and I have been plagued with SD Card Errors.When I first tried to
print I received the error and had to open the back of the printer take out the SD card and put it back in to get it to work. I was then able to print successfully.
The next day I tried to print and I had the same issue. Again taking out and returning the SD card fixed it. However midway through the print the printer again returned an SD Card Error.
Is there anything I can do to solve this issue (preferably without having to send the printer in for repairs or get a replacement part)? At the moment it doesn't seem to be recognising the SD card at all. I've established the following:
Running UpInspector.exe returns a No SD Card Error.
I have tried with another SD card and that didn't help.
I have tried "reseating" the SD card and that no longer seems to help.
The problem seems to be getting worse. Now I can't to get it to recognise the SD card at all, or very rarely.
I imagine it could be poor solder joints but they don't look bad to me and I'm really not too keen on resoldering it lest I void the warranty. I've noticed a number of people on here seemed to have the same issue; is the only recourse getting it replaced/repaired?
Faulty Up Mini - SD Card errors
Re: Faulty Up Mini - SD Card errors
well that is beyond my experienced. in worst case i advice you to change the printer and work on a new and not wireless printer for sure. if you still having a problem with that, you can contact the official tech for making sure of it.
Printer and Barcode Solutions - AGMTech
