I wanted 2 copies of a component, so I loaded it once then I added an additional copy via the UP right click "insert copy" function.
It wasn't a very complex item, as you can see from the attached pic, just an end cap with a cavity for a cover strip.
I printed the item on its back, so there was almost no support material required.
One of the items ( pretty sure it was the copy, but can't be certain) was printed with the cover strip cavity half filled with what looked like raft structure i.e not solid just an open criss-cross of material.
A subsequent single re-print of the item turned out OK
Any clues please?
Thank you
Ian
Not all copies are equal
- Attachments
- end cap.JPG (41.06KiB)Viewed 3961 times
Re: Not all copies are equal
Hi
looking at the image, that could be the much wanted new Upsized Up!Mega
Lawrence
Lawrence
