Lookey what I made
jeeplvr
Lookey what I made
Post by jeeplvr » Mon Jan 06, 2014 7:01 am
Its a fully functional Dynamo Light made with an UP Mini.
I have two working models.
jeeplvr
Re: Lookey what I made
Post by jeeplvr » Mon Jan 06, 2014 7:08 am
And the first test of the first prototype.
http://youtu.be/XNj1datjETQ
ftdesigns
Post by ftdesigns » Mon Jan 06, 2014 12:17 pm
that's pretty sweet. did you also print the bearing?
Post by wackojacko » Tue Jan 07, 2014 3:35 am
Just sent you a PM
jeeplvr
Post by jeeplvr » Tue Jan 07, 2014 5:16 am
ftdesigns wrote:that's pretty sweet. did you also print the bearing?
The bearing is steel and was purchased. The only things not printed were the bearings, screws, wires, LED's, and the dynamo (generator). The housings, gear, handle, chain drive, and covers were all printed from ABS. I designed the entire thing in Solidworks.
