Food-Safe Coating?
UPUPandAway
Food-Safe Coating?
Post by UPUPandAway » Sun Dec 02, 2012 4:31 am
Does anyone know of something that could be painted onto the surface of an ABS part to make it food safe for dry food? Does dry food even have a toxic seepage problem with non-food safe materials (assuming nothing toxic was previously put in the container)? I was wondering specifically because of a salt and pepper container I was working on and wanted to see if anyone was knowledgeable about dry food and how it applies to food safe containers.
FallGuy
Re: Food-Safe Coating?
Post by FallGuy » Sun Dec 02, 2012 6:27 pm
I know that they make food grade ABS available in sheets of various thickness for all sorts of uses, but I have never seen it in a filament form that could be used in a printer. I have used food grade silicone to make mold cavities for customized chocolates, mints and hard candies. Here is a site that has some information on it,
http://www.makeyourownmolds.com/
You can even find more on it if you do a search for it on Amazon.com.
I am not sure how much "bad stuff" there could be transferred from our ABS to foods, but the silicone is so cheap and easy to use to act as a sealant, i always do.
Thanks,
FallGuy
