Nearly perfect sphere
amd-tec
Post by amd-tec » Wed Aug 21, 2013 7:14 am
Not new idea, but might be usefull in some cases.
Inspired by this http://www.thingiverse.com/thing:135716 I printed sphere with block support.
There is a 0.2 mm gap between block and sphere. Printed with 0.15 mm layer and fine mode.
Arrows shows the bottom side which is usually the hard side to print...
Thanks,
amd-tec
Sphere testing
http://www.amd-tec.com
Re: Nearly perfect sphere
Post by wackojacko » Wed Aug 21, 2013 7:39 am
If you print with the wind barrier open the under side curves are much better
amd-tec
Post by amd-tec » Wed Aug 21, 2013 11:04 am
wackojacko wrote:If you print with the wind barrier open the under side curves are much better
In those prints wind barrier was half open, here`s the results when wind barrier is fully open. The settings was same.
It`s closer but still "far" away.
WB full open
B1-wb-full open.jpg (43.8KiB)Viewed 7184 times
