Turn off the beep!
muzoodesign
Turn off the beep!
Post by muzoodesign » Tue Jul 17, 2012 9:57 am
anyone know how to turn off the beep made when the printer is starting up and ready. Or reduce its volume?
I work in a very quite office and its starting to drive the others crazy, me too...
Re: Turn off the beep!
Post by wackojacko » Tue Jul 17, 2012 11:08 am
Open up the base cover and put a bit of tape over the black speaker next to the CPU.
www.3dprintingsystems.com
muzoodesign
Post by muzoodesign » Tue Jul 17, 2012 11:42 am
Good one from downunder!
TTT험ทดสอบ
Post by TTT험ทดสอบ » Tue Jul 17, 2012 1:37 pm
muzoodesign wrote:anyone know how to turn off the beep made when the printer is starting up and ready. Or reduce its volume?
Hi, We will release a ROM without the beep next month. ;)
Darkhouse.
Fairly
Post by Fairly » Tue Jul 17, 2012 8:00 pm
Great news!
When I tape up the speaker on the mobo I get a drowning cat sound instead of a beep.
wilsonj
Post by wilsonj » Tue Jul 17, 2012 9:17 pm
Darkhorse, any hints about what else might be in the new ROM???
CarryTheWhat
Post by CarryTheWhat » Tue Jul 31, 2012 4:00 am
seconded..
Eurisko84
Post by Eurisko84 » Wed Sep 19, 2012 4:22 am
I have found that a bit of tape really only changes the pitch... but the volume is identical.
A much better solution (and makes the speaker practically inaudible) is to use a small bit of foam or sponge (and I mean tiny) and just wedge it ever so slightly into the hole.
Buzzers like this one work by forcing air through the hole and surround. If you cover the hole, the air still flows out of the surround, only changing the tone. Foam allows air through, but disrupts the flow - effectively muffling the speaker.
It works so well, you actually have to pay attention to when it is ready!
wilsonj
Post by wilsonj » Wed Sep 19, 2012 7:57 pm
Darkhouse.
Any news on this new release?? I'm using 1.17beta, but it doesn't seem to have the feature to turn off the beep
walter
Post by walter » Sun Oct 07, 2012 6:53 pm
I used a small speaker cover to reduce the volume. I uploaded the stl file to thingiverse in case anyone else wants to do the same.
http://www.thingiverse.com/thing:31957
Post by wackojacko » Mon Oct 08, 2012 4:37 am
We have the final version of 1.17 with new Rom available and this version reduces the beep duration, get it here www.3DPrintingSystems.com/support
marcviader
Post by marcviader » Thu Nov 01, 2012 10:52 am
Please,
where is the speaker?
have you already finished the rom version which allow to turn off the beep?
many thanks
Marc
Marc
Post by wackojacko » Thu Nov 01, 2012 7:20 pm
There is no off, but in the new ROM the beeps are shorter. Best to open up the 3D printer and silence the speaker manually if you need it silenced.
Blown454
Post by Blown454 » Fri Nov 02, 2012 3:33 am
I finally upgraded Rom to latest last night and am so darn pleased with the shorter 'beeeeps!'! Thank you, thank you for that! :). I had already printed the little speaker cap and put that on, but this is really nice now having it both quieter and now much shorter. It is acceptable now for the whole family.
Post by wackojacko » Fri Nov 02, 2012 5:02 am
Glad you have a quiet beeping house.:)
alcrp
Post by alcrp » Sun Sep 11, 2016 2:35 pm
This worked the best for me, screwing it, with the oportunity to really adjust it as if it was a real adjustment button... :)
See below the attached picture:
