Print quality of the new colored ABS?
Has anyone tried the (for me) new color ABS from PP3DP? It's probably as good as the white but has anyone had chance to try it yet?
Cheers!
Cheers!
Re: Print quality of the new colored ABS?
Yes - see here:
https://isupply3d.com/UP-Printer-Sectio ... r-filament
Each coloured spool has extra images of prints - just remember the actual colour may differ due to lighting conditions when photographed.
For me the Black is the most impressive
I bought a spool of black, and it's really, really good. Light years beyond any other black I've tried.
I bought also black filament, working great, looks nice. Will post
pics later.
pics later.
http://www.amd-tec.com
Here`s one.amd-tec wrote:I bought also black filament, working great, looks nice. Will post
pics later.
Note it`s printed with 0.3 mm layer.
- Attachments
- Black color
- b1-2.jpg (66.04KiB)Viewed 25798 times
Yep, Black seems the best so far but Blue isn't bad either...
- Attachments
- blue-part.jpg (37.41KiB)Viewed 25771 times
Man, that black does look good!
I'm so pissed about this, I bought 2 spools of natural ABS and then the colored spools debuted like a week or two later! I've been wanting to print in black for so long...
Does the black hide imperfections as well as the natural, though? Does it have that "softening" effect on the ridges to make it look better at a glance? It's hard to tell from pictures as things always look more ribbed in photos.
I generally find the darker the filament the more it shows the layers. Regardless of the brand. The whites and creams look best in this regard. Black the worst.
I'd normally agree with this but the official black has a matt surface to it which seems to reduce the visibility of the layers when compared to other colors.I generally find the darker the filament the more it shows the layers. Regardless of the brand. The whites and creams look best in this regard. Black the worst.
I'll have to post some more photos when I get a minute...
That's right.. the matt surface looks more nice than glosy surface.
I like OEM filament's matt feeling of the surface.
I think the worst looking filament is the plaster like grey filament.
It shows true layers, so not good looking.
But lots of modelers like that filament because it can make the exact post work on surface.
Following photo as for example.
The grey model partly sanded. it looks nice.
She looks 20 years older than others because of my bad post work skill.
Interesting. I have a mat black filament, but I haven't tried printing with it yet. Perhaps it will be better than the normal glossy black.eyUP wrote:I'd normally agree with this but the official black has a matt surface to it which seems to reduce the visibility of the layers when compared to other colors.I generally find the darker the filament the more it shows the layers. Regardless of the brand. The whites and creams look best in this regard. Black the worst.
Incidentally I have a Stratasys Mojo sample in ivory and their filament is SUPER glossy. Not sure if that is an effect from the bath or how it comes out normally.
Great comparison shots jspark! I need a macro lens!jspark wrote:That's right.. the matt surface looks more nice than glosy surface.
She looks 20 years older than others because of my bad post work skill.![]()
Here is another item using the official black ABS. Also printed at 0.15
- Attachments
- Valve.jpg (33.56KiB)Viewed 25576 times
It looks like it behaves pretty well
Do you clean out the extruders before changing color or does the previous color disappear pretty quick after changing?
One or two extrudes is enough to see a consistent new color...I've never had to clean a nozzleIt looks like it behaves pretty well Do you clean out the extruders before changing color or does the previous color disappear pretty quick after changing?
Does anyone know where to buy this in the UK?
The only place I'm aware of is iSupply3D, but they only sell twin packs and that makes it very expensive to buy one of each colour.
Could be from a finishing bath, but the Mojo uses SABIC MG94 resin (what they call 'ABSplus'), while the Standard Stratasys P400 ABS is a very low-gloss material (and it's quite possible that Beijing Tiertime is using the exact same resin - likely Dow Magnum AG700).wilsonj wrote:Interesting. I have a mat black filament, but I haven't tried printing with it yet. Perhaps it will be better than the normal glossy black.
I'm only just getting started with my Up (which I won on Instructables) but I may be interested in going halves with you on a twin pack.
Fred (in Surrey, UK)
Hi Fred,
Cool components will soon be stocking the oem colours.
Hopefully they will sell single rolls as they do with the white.
I just asked Cool Components and they're expecting to have the coloured ABS in about a week. I didn't ask whether they'd sell as single reels, but no reason to think they wouldn't as that's now they current sell the white.
Umm.... how do you print at .15? My settings only go down to .2? Does the printer support higher resolutions?eyUP wrote:Here is another item using the official black ABS. Also printed at 0.15
