UP Mini getting worse and worse
Xonor13
Post by Xonor13 » Sun Mar 19, 2017 12:21 am
My UP Mini has been having a lot of issues lately. UP Studio constantly has issues finding and connecting to the printer. I have no idea what is causing the issue because it happens randomly. When i connect the printer to my computer everything is fine for a few prints and then half way through a print sometimes the extruder will just stop extruding filament but continue to move around. While this happens i can't turn the print off on the computer because my computer just randomly loses its connection between my printer when this issue happens, so i'm forced to use the off switch in the back. Another issue is after a few prints my printer will just lose connection with UP Studio and then i have to turn the printer on and off about 3-4 times and then it finally realizes it is connected to my computer. Meanwhile, my computer knows it is connected all the time.
Here is a video of the issue.
https://youtu.be/8C3wOSpVXwo
Another issue that happens when i'm trying to reconnect my printer to UP Studio is that my printer will be seen as this.
Screenshot (12).png (73.01KiB)Viewed 4562 times
I only have one printer and i didn't name it whatever it says there. Either way the program acts like it doesn't see it anyways so i can't connect to it.
Here is a picture of what it looks like whenever the printer actually is found and connected in UP Studio.
Screenshot (13).png (81.27KiB)Viewed 4562 times
I have tried older software versions and they all do the same thing. Here are the log files
Code: Select all
[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[ TierTime Begin ]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]
用户双击模型,打开程序与模型:C:\Program Files\UP Studio\win64\UPStudio.exe
before CefExecuteProcess
GetPrinterInformation from config success
BeginUpdate...
GetPrinterInformation Printername: Dan's UP Mini SN: 0
SetPlaneSize -120 0 0 120 130
GetUpdateInfo...
ConnectLastedPrinter...
Thread_BEGIN_UpdateOtherStatus
Thread_BEGIN_BackServiceThread
ConnectPrinter[USB]:75525 Error
WM_PAINT
GetUpdateInfo OK
BeginUpdate error : ServerVer <= CurrentVer SerVer:1.6.1.2 CurVer:1.6.1.2
BackServiceThread 传送成功
Send:https://www.up3d.com/winnipeg/api?apiName=uploadServiceInfo&serviceInfo={'Date':'2017-03-18 22:01:13','Language':'en','Os':'Microsoft Windows 10','CurrentVer':'1.6.1.2','PrinterSN':'999999','Count_Model_Rotate':'1'}
Receive:{"result":0,"code":"00200","message":"Succeed to upload the service info."}
Thread_BEGIN_ChromeBrowserCallback::async_read_printer_status
async_web_load_finished BEGIN
BEGIN OpenDragFiles
OpenDragFile ext ERRORC:\Program Files\UP Studio\win64\UPStudio.exe
GetVideoInfo_Json OK:[{
"url": "https://www.youtube.com/embed/aTH97xB-kGQ",
"title": "Withdraw the filament",
"path": "tiertime://crypte/C:%5CUsers%5CDaniel%20Parker%5CAppData%5CRoaming/Tiertime/Data/Video/w11.png"
"url": "https://www.youtube.com/embed/x1ISld0vrEE",
"title": "Extrude the filament",
"path": "tiertime://crypte/C:%5CUsers%5CDaniel%20Parker%5CAppData%5CRoaming/Tiertime/Data/Video/w12.png"
"url": "https://www.youtube.com/embed/uvRXdyqgQ_A",
"title": "Remove model from print bed",
"path": "tiertime://crypte/C:%5CUsers%5CDaniel%20Parker%5CAppData%5CRoaming/Tiertime/Data/Video/w13.png"
"url": "https://www.youtube.com/embed/izDC4_wRkoQ",
"title": "Pause",
"path": "tiertime://crypte/C:%5CUsers%5CDaniel%20Parker%5CAppData%5CRoaming/Tiertime/Data/Video/w14.png"
"url": "https://www.youtube.com/embed/14t8uR947Z0",
"title": "Remove the support",
"path": "tiertime://crypte/C:%5CUsers%5CDaniel%20Parker%5CAppData%5CRoaming/Tiertime/Data/Video/w15.png"
"url": "https://www.youtube.com/embed/QA9UT58HVDE",
"title": "Pause and resume the 3D Printer",
"path": "tiertime://crypte/C:%5CUsers%5CDaniel%20Parker%5CAppData%5CRoaming/Tiertime/Data/Video/w16.png"
ChangeColor: color-default
RunJSFunc 1 Color.change('color-default');
RunJSFunc 2 Color.change('color-default');
async_web_load_finished END
AutoLogin BEGIN
Send:https://www.up3d.com/winnipeg/api?apiName=uploadServiceInfo&serviceInfo={'Date':'2017-03-18 21:35:41','Language':'en','Os':'Microsoft Windows 10','PrinterSN':'75525','UserID':'33e4ef02-add0-11e5-9d94-d8cb8a7499d8','PrinterModel':'UP mini','Material':'PLA','RemainedMaterail':'436','NozzleTemp':'210','PlatTemp':'46','ModelFacetNum':'25116','ModelSize':'44.8558x51.1686x7','LayerThick':'0.25','FillStyle':'Loose','Quality':'FAST','MaterialUsed':'3.41','PrintTotalTime':'18m','CurrentVer':'1.6.1.2'}
GetBannerInfo_Json OK:[{
"url": "https://www.up3d.com/blog/?p=307",
"title": "",
"path": "tiertime://crypte/C:%5CUsers%5CDaniel%20Parker%5CAppData%5CRoaming/Tiertime/Data/Banner/14787466420722.jpg"
"title": "",
"path": "tiertime://crypte/C:%5CUsers%5CDaniel%20Parker%5CAppData%5CRoaming/Tiertime/Data/Banner/14785855316444.jpg"
"url": "https://www.up3d.com/?r=upboxplus",
"title": "",
"path": "tiertime://crypte/C:%5CUsers%5CDaniel%20Parker%5CAppData%5CRoaming/Tiertime/Data/Banner/14781549797404.jpg"
pixelFormat color bits : 32
pixelFormat depth bits : 24
pixelFormat stencil bits : 8
OpenGL Driver Info
Vendor: NVIDIA Corporation
Version: 4.5.0 NVIDIA 378.78
GLSL Version: 4.50 NVIDIA
Renderer: GeForce GTX 1050 Ti/PCIe/SSE2
Color Bits(R,G,B,A): (8, 8, 8, 8)
Depth Bits: 24
Stencil Bits: 8
Max Texture Size: 32768x32768
Max Lights: 8
Max Clip Planes: 8
Max Modelview Matrix Stacks: 32
Max Projection Matrix Stacks: 4
Max Attribute Stacks: 16
Max Texture Stacks: 10
GL_ARB_vertex_buffer_object support!
OpenGL version 4 GL_ARB_framebuffer_multisample && GL_ARB_framebuffer_object support !
Video card supports WGL_EXT_swap_control.
Origin VSYNC Value: 1
SetUpMultiSample frameBufferStyle: 1
RunJSFunc 1 SYNC.Login('33e4ef02-add0-11e5-9d94-d8cb8a7499d8','ktg7y4BrnG','Xonor13');
AutoLogin OK,UserName: Xonor13
2017/03/18 22:01:55.459 async_read_printer_info
Send:https://www.up3d.com/winnipeg/api?apiName=uploadServiceInfo&serviceInfo={'Date':'2017-03-18 21:18:23','Language':'en','Os':'Microsoft Windows 10','PrinterSN':'75525','UserID':'33e4ef02-add0-11e5-9d94-d8cb8a7499d8','PrinterModel':'UP mini','Material':'PLA','RemainedMaterail':'440','NozzleTemp':'210','PlatTemp':'46','ModelFacetNum':'36','ModelSize':'12x100x80','LayerThick':'0.35','FillStyle':'Solid','Quality':'FAST','MaterialUsed':'27.33','PrintTotalTime':'82m','CurrentVer':'1.6.1.2'}
2017-03-18 22:01:56【PrinterStatusChange】PrinterString : Printer not Connected NEW:-1 OLD:-2
2017-03-18 22:01:56【PrinterStatusChange】MaterialChange Name : ConnectType:0 Material:PLA
【HeatStatus Changeto 】0
2017/03/18 22:01:56.986 async_read_printer_info
Send:https://www.up3d.com/winnipeg/api?apiName=uploadServiceInfo&serviceInfo={'Date':'2017-03-18 20:22:30','Language':'en','Os':'Microsoft Windows 10','PrinterSN':'75525','UserID':'33e4ef02-add0-11e5-9d94-d8cb8a7499d8','PrinterModel':'UP mini','Material':'PLA','RemainedMaterail':'467','NozzleTemp':'210','PlatTemp':'46','ModelFacetNum':'396','ModelSize':'9.5x9.48126x73','LayerThick':'0.3','FillStyle':'Loose','Quality':'NORMAL','MaterialUsed':'2.21','PrintTotalTime':'14m','CurrentVer':'1.6.1.2'}
====== CANCEL
====== CANCEL OK
Cancel Detail ====
Cancel Detail OK ====
async_setfocus_disc:0
Thread_END_BackServiceThread
[PrinterChanged] Relinked
【UpdatePrinter】 打印机重新连接,更新打印机信息与平台尺寸
GetPrinterInformation from printer success
GetPrinterInformation Printername: Dan's UP Mini SN: 75525
SetPlaneSize2-12000120130
CheckActive Begin
[PrinterChanged] USB Printer Changed
FirmwareVer<345,return
[PrinterChanged] SN changed to 75525
2017-03-18 22:01:59【PrinterStatusChange】PrinterString : Printer not Initialized NEW:0 OLD:-1
2017-03-18 22:01:59【PrinterStatusChange】PrinterChange NameChange Name : Dan%27s%20UP%20Mini ConnectType:0 Material:PLA
2017/03/18 22:01:59.063 async_read_printer_info
CheckActive Begin
GetPrintParamFromServer ERROR Model: 10003 Receive: {"result":"1","message":"未找到对应的设备属性。"}
Initial Printer ...
wait...
2017-03-18 22:02:04【PrinterStatusChange】PrinterString : Printer not Initialized NEW:0 OLD:0
CheckActive Begin
2017-03-18 22:02:04【PrinterStatusChange】PrinterChange Name : Dan%27s%20UP%20Mini ConnectType:0 Material:PLA
[USB Lock Error] IsSystemIdle
2017/03/18 22:02:04.121 async_read_printer_info
CheckActive Begin
wait...
wait...
wait...
wait...
wait...
wait...
wait...
wait...
wait...
wait...
wait...
wait...
wait...
wait...
wait...
wait...
wait...
CheckActive Begin
2017-03-18 22:02:42【PrinterStatusChange】PrinterChange Name : Dan%27s%20UP%20Mini ConnectType:0 Material:PLA
2017/03/18 22:02:42.493 async_read_printer_info
CheckActive Begin
wait...
Initial Printer Finished
RunBreakLayer Begin
RunBreakLayer error: FirmwareVer < 351
async_setfocus_disc:1
RunBreakLayer Begin
2017-03-18 22:02:44【PrinterStatusChange】PrinterString : Printer Ready NEW:1 OLD:0
CheckActive Begin
RunBreakLayer Begin
2017-03-18 22:03:03【PrinterStatusChange】PrinterChange Name : Dan%27s%20UP%20Mini ConnectType:0 Material:PLA
2017/03/18 22:03:03.264 async_read_printer_info
CheckActive Begin
CheckActive Begin
RunBreakLayer Begin
2017-03-18 22:04:50【PrinterStatusChange】PrinterChange Name : Dan%27s%20UP%20Mini ConnectType:0 Material:PLA
2017/03/18 22:04:50.985 async_read_printer_info
CheckActive Begin
未找到对应的设备属性 is not my printer name and i don't know why it changes or can't connect. Sometimes the printer connects fine and there are no issues and then others it just goes crazy and it doesn't work.
