USB inside the Case
Share your experience with UP300!
Jogy
USB inside the Case
Post by Jogy » Sat Mar 16, 2019 5:22 pm
For what use is that USB connector inside the case on the upper back wall?
JothamB
Re: USB inside the Case
Post by JothamB » Tue Mar 19, 2019 7:38 pm
It only has 5v supplied to it. I guess you can hook up a wifi camera to it or some other accessory? I have no idea honestly.
cj7hawk
Post by cj7hawk » Fri Mar 22, 2019 12:22 pm
There's a lot of unused connectors on the board, because it looks like it was originally intended for a different machine. If I recall correctly, the connector on the board is wired, via the plug nearby, to go to the back of the printer, and is the printer port.
JothamB
Post by JothamB » Sun Mar 24, 2019 12:06 am
Well its super convenient if you ever put the aftermarket open source smoothieware CPU into it and run it with octoprint. Octoprint is a open source print server that can provide a live feed of the print via the app or your browser, it can even render timelapses its pretty nifty I've used it for years on my hobby 3D printer.
