[Bug Report] Wall still not attached to infill 19th March 2019 firmware.
Support for UP300. To report a bug, post with a title [BUG REPORT]. To request a feature, post with a title [FEATURE REQUEST]
cj7hawk
Post by cj7hawk » Fri Mar 22, 2019 2:13 pm
Just tried the default 100% Fill on a model with default settings, 0.1mm layers.
The outer will is still not attached to the infill, with the worst affect being on the right rear side ( that is, the right side, or rear side, will show the worst separation between the wall and the fill, or in a circle, the right, rear side of the print. )
Is anyone from Tiertime able to confirm that you're aware of the problem? It seems to be affecting 100% of your users presently.
David.
cj7hawk
Re: [Bug Report] Wall still not attached to infill 19th March 2019 firmware.
Post by cj7hawk » Sat Mar 23, 2019 3:01 am
File that generates the test shape;
3mm square box test for walls.zip
(425 Bytes) Downloaded 53 times
allineatorisorridi
Post by allineatorisorridi » Wed Apr 10, 2019 9:06 am
Downgrade to software 2.5.x solve the problem!
cj7hawk
Post by cj7hawk » Wed Apr 24, 2019 12:48 pm
What is the board firmware to support this? Now I've upgraded it, it just errors out when I try to run 2.5.x -
I'm not sure it's safe to downgrade after the recent string of firmware failure updates, especially as I'm on the latest.
