Hi everyone, i've a problem with my new up300.
I can't calibrate correctly the plate, when is ok in the back side is too high on the front and viceversa.
I've tried both auto and manual mode.
Thanks in advance
Impossbile Calibration
Re: Impossbile Calibration
Calibrating it manually should still work. They include a card for doing it manually.
At what point does the process fail for you?
Solved thanks
It's always helpful if people post how they solved their problem.
Owen S.
Sorry i was in a hurry! Under the plate there are 4 thumbscrew for adjusting it!!
