up300 with external slicer
Support for UP300. To report a bug, post with a title [BUG REPORT]. To request a feature, post with a title [FEATURE REQUEST]
qwertz32
Post by qwertz32 » Sun Jan 27, 2019 8:19 pm
hi , is anbody using an external slicer programm instead of the tiertime slicer ? i am thinking s3d cura slic3r or anything else that produces executable gcode ? best regards
BigE79
Re: up300 with external slicer
Post by BigE79 » Sat Mar 02, 2019 2:38 am
I just tried using Simplify 3D with their trial version but I didn't have any luck. I followed the TierTime instruction exactly as per the PDF (using upbox+ settings) but when I went to import the G-code it just showed an error. Something about unable to recognize command. I don't know if it needs to be connected directly via USB or if the UP300 simply doesn't support the G-code import. TierTime's manual does not specifically cover the UP300.
TierTime can you clarify if this is possible?
I wanted to use an external slicer as Upstudio does not always slice the way I like, for example:
- 99% fill reduces the wall thickness to 1 layer.
- There's often gaps in the fill on top layers and the fill does not perfectly follow the edge.
- You can't adjust edge thickness.
I looked at Cura also but there doesn't seem to be a way to support the Z calibration at the bottom of enclosure. There's a Z-offset plug-in but it works the other way only.
Good thing Simplify 3D has a trial period.
bjorn
Post by bjorn » Sat Mar 02, 2019 4:53 am
I haven't followed the g-code thread closely but I do recall it only being supported by some models/firmwares, and that some older versions simply can't and won't be supported. Maybe check if yours can be updated or what version its at?
There is also an alternative g-code transcoder project, which will take "normal" g-code and re-write it to the weird coordinate system used by Tiertime, but I never bothered trying as my printer is uable to print without a raft anyway, and then Up Studio kinda works. When I modify the bed I'm not going back to Up Studio however.
Post by Owen Sparks aka Marksman » Mon Mar 04, 2019 8:06 am
The UP300 is the brand new machine, with updatable firmware that we've been promised works with GCODE, so it should be good to go.
O.S.
BigE79
Post by BigE79 » Sat Mar 09, 2019 11:11 pm
I only get errors when I start to print. Something about unknown command.
I wish there were some more detailed instructions from Tiertime on this. I'd like to know if a gcode steam is sent from the PC or a task file is sent to the printer first? Can it run over wifi or should it be USB connected? Are there any other things to look out for?
Like I said I followed the PDF instructions perfectly and it doesn't work. It's not even that it's not printing well. It doesn't even start.
cj7hawk
Post by cj7hawk » Mon Mar 11, 2019 12:46 am
Hi BigE79,
Can you please try setting your extrusion width to 0.6 and printing at 99% and let me know if that fixes the detached wall problem for you also?
I find it keeps defaulting back to 0.45 a lot, but I find that at 0.4, 0.5 and 0.7 I still get the problem. At 0.6, it seems to go away for some reason.
Also I find it often seems worse on different model wall thicknesses ( eg, around 2.0mm )
Just wondering about the characteristics you're experiencing.
David.
fastm3
Post by fastm3 » Wed Mar 13, 2019 9:43 am
Same thing here. I've tried everything and I always get an error before starting. For exemple:
fff files for simplify3D or at least Gcode simple exemple files would help to understand what's wrong.
I'm using the latest beta. I've bought the up300 because gcode support was on the specs sheet.
BigE79
Post by BigE79 » Fri Mar 15, 2019 9:25 pm
Yep: To confirm, that's the same error I get.
Post by Owen Sparks aka Marksman » Wed Jun 05, 2019 9:06 am
Any news on the UP300 and GCODE? We were promised it would be supported on launch a year ago so if it hasn't been implemented by now I'm worried.
Cheers, Owen S.
bjorn
Post by bjorn » Wed Jun 05, 2019 11:28 pm
Maybe the new slicer will generate "up-code" that works? No idea why I'm suddenly an optimist.. :lol:
Post by Owen Sparks aka Marksman » Thu Jun 06, 2019 9:11 am
Yeah, but we want to use S3D now, not potential TT software maybe some time in the future...
bjorn
Post by bjorn » Sat Jun 08, 2019 8:22 pm
Lol, yeah, sorry, that was a bit bad taste.
Post by Owen Sparks aka Marksman » Tue Jun 11, 2019 11:22 am
No, no, its all good :lol:
Post by Owen Sparks aka Marksman » Wed Jun 12, 2019 8:53 am
Actually I'd like to use the copy of Simplify3D that I only bought (at a cost of $149) because TT said it would work with my UPBOX...
