Printhead Entombed
Ramatu
Printhead Entombed
Post by Ramatu » Sun Jan 13, 2019 2:59 am
My printhead was entombed after a print. It seems like this may be a common issue as it happened with a previous Up Mini 1. Interestingly, the raft that I pulled off of the failure seemed thicker than a normal raft. The print at first seemed overextruded, but I don't think it was. I believe the raft became unattached mid-print due to lack of adhesion. I've already ordered a replacement printhead.
My questions:
1. Has anyone else had this issue?
2. Does anyone, or the mods, have advice to reclaim this hot head?
Re: Printhead Entombed
Post by Owen Sparks aka Marksman » Mon Jan 14, 2019 8:20 am
Is that PLA or ABS? If ABS then acetone will dissolve it eventually!
Ramatu
Post by Ramatu » Mon Jan 14, 2019 3:48 pm
Fortunately, it is ABS. I like that idea -- do you think it would damage, or compromise, the wire insulation or sleeves?
Either way, I'll give it a try this evening and post the results as soon as I have something. There's only one way to go from here.
Ramatu
Post by Ramatu » Thu Jan 17, 2019 9:12 pm
After 20 hours in 2 separate baths (dilution and evap), here are the results.
Now she just has to print herself some new clothing.
Post by Owen Sparks aka Marksman » Fri Jan 18, 2019 7:50 am
Well done, great work 8-)
