I had a print fail half way through the build. It turns out the printer head got clogged, which wasn't that big of a deal to fix. This has happened every now and then.
The current problem is that the ABS material that I am printing with is only extruding in curls now. Is there a problem with the heat settings? Is there an issue with the thermostat? Any help regarding this issue would be appreciated.
ABS extruding in Curls
Re: ABS extruding in Curls
Hi friend,
The nozzle is blocked, you can try a new nozzle
