Nozzle material
YoHidden
Nozzle material
Post by YoHidden » Tue Mar 27, 2018 5:13 pm
Hi there,
I'm willing to give a try to the filament PETG-Carbon, just to se if I can avoid warping effect wth ABS. I've seen in the Up mini 2 specs that this is one of the compatible materials for filaments. But I've also seen that brass or bronze nozzles should not be used with this kind of abrasive materials.
So my question is... what's the material of the nozzle that comes with the Up mini 2 out of the box ?
Thanks.
Tiertime-Elaine
Re: Nozzle material
Post by Tiertime-Elaine » Wed Mar 28, 2018 11:46 pm
Hi YoHidden,
It is made of brass.
We suggest you use stainless steel nozzle for printing PETG- Carbon.
Elaine
YoHidden
Re: Nozzle material
Post by YoHidden » Fri Mar 30, 2018 10:26 am
Thanks for the reply. And just to be sure... the nozzle diameter is 0.4mm ?
Re: Nozzle material
Post by Owen Sparks aka Marksman » Fri Mar 30, 2018 3:16 pm
Yes, M6 fine female.
YoHidden
Re: Nozzle material
Post by YoHidden » Tue Apr 03, 2018 2:23 pm
Is it the same nozzle type used for UP Plus, UP Mini and the Up Box (manufactured after March 2015) ?
Re: Nozzle material
Post by Owen Sparks aka Marksman » Tue Apr 03, 2018 10:22 pm
Mini 2, UPBOX and UPBOX+ are all the same, I'm afraid I can't comment on the earlier models.
O.S.
tiertimefreya
Re: Nozzle material
Post by tiertimefreya » Fri Jun 08, 2018 6:50 am
PLUS MINI BOX (manufactured after March 2015)
All brass nozzles, model is V2
https://www.ebay.com/itm/282941616967
