side wall thickness
grupawrc
side wall thickness
Post by grupawrc » Fri Jan 27, 2017 6:49 pm
I try to print wall thickness in my model ( have 4 mm ) but the print is only 1 mm.
how to change it ?
the green one is for mini2 and the black from other printers
menno
Re: side wall thickness
Post by menno » Sat Jan 28, 2017 11:09 am
Try to rotate your part 45 degrees around Z-axis and print again.
Jerry Hu
Post by Jerry Hu » Sat Feb 04, 2017 7:08 am
Can you share the Model ?I want to try, maybe can help you. My e-mail is 411837969@qq.com
iMUTEKI
Post by iMUTEKI » Tue Apr 18, 2017 9:57 am
is there a way to change side wall thickness? i thought surface layers would do all surfaces but it looks like it only affect the top
