Air Flow Adjustment
Surge
Air Flow Adjustment
Post by Surge » Mon Oct 03, 2016 3:35 am
The manual is not very clear on this - which way should it be set - towards the front or the rear of the printer - for ABS printing?
Surge
Re: Air Flow Adjustment
Post by Surge » Tue Oct 04, 2016 1:52 am
My retailer helped: towards the front diverts air away from the nozzle, so that's the suggested position for ABS prints.
tel
Post by tel » Tue Oct 04, 2016 2:16 am
For ABS make sure the air is not blowing on the nozzle/print. So whatever opening faces the nozzle should be closed.
Post by wackojacko » Tue Oct 04, 2016 6:18 pm
For large models door closed for:
Printing raft
First few layers of model
If you want to improve print quality then open the door up.
Stronger parts
ABS
Door open
Pla, quality gets even better with adding extra cool air
Parts are not as strong
Can cause lifting
