Accuracy on Z-axis
slmka
Accuracy on Z-axis
Post by slmka » Mon Apr 24, 2017 4:36 pm
I notice on my UP!Mini 2 when printing the Z-axis is always a bit higher, approx 1mm most of the time.
Currently I am printing on UP! ABS filament, for prints between 0.15 ~ 0.3 also have similar problem.
Is there anyway I can improve on the print as some of the prints need to be assembled and this becomes a challenge for these.
Thanks.
Tiertime_Bryant
Re: Accuracy on Z-axis
Post by Tiertime_Bryant » Thu Apr 27, 2017 7:14 am
slmka wrote:I notice on my UP!Mini 2 when printing the Z-axis is always a bit higher, approx 1mm most of the time.
Thanks.
First,please calibrate the nozzle height:
Then,if it alwaws too high,you'd better give it an appropriate compensation value (Nozzle offset) between -1mm and 0mm.
Please try it!
Nozzle offset.jpg (169.31 KiB) Viewed 6046 times
Nozzle Detect.jpg (126.85 KiB) Viewed 6046 times
