Nozzle Digging into Board
CCNA
Post by CCNA » Mon Jul 16, 2018 8:25 pm
After clearing the settings and doing an auto-level, which also checks nozzle height, I am having a problem where it seems the nozzle is too low and is digging into the non-stick surface on the print board. I have tried a manual level, but that doesn't seem to be much better. Any thoughts on what to do?
Tiertime-Elaine
Re: Nozzle Digging into Board
Post by Tiertime-Elaine » Thu Aug 23, 2018 7:23 am
Hi CCNA,
Have you checked the value of Nozzle Offset in the software? How to find the: open the software go to UP-> click Print -> you will find the Nozzle offset.
Here's a tutorial of how to calibrate the printer manually: https://www.tiertime.com/9-point-calibration-method/
Hope above helps a bit.
Elanie
