Upgrading Box to print Carbon Fiber?
ajohnsonlaird
Post by ajohnsonlaird » Sat Mar 24, 2018 7:48 pm
Anyone know whether the upgrade kit (https://store.tiertime.com/products/big ... y-tiertime) allows an Up Box (original not the Plus) to then print the new filament that the Box+ can (e.g. carbon fiber, etc.).
Thanks in advance
Andy
UpBox and UP Plus 2 : Forensic Software Analyst : Portland, Oregon, USA.
brunningm
Re: Upgrading Box to print Carbon Fiber?
Post by brunningm » Sat Mar 24, 2018 10:41 pm
I'm not even sure you'd need the CPU upgrade. Does the latest Upstudio allow your model to change nozzle and bed temps from the UPfila standards? It prints around 230-250 which is well within the ranges of the heater block, as it prints ABS at 270 on mine by default.
If so, all you'd really need is a hardened nozzle, which are annoyingly going to need to be in the female variety. You can try the Micro-Swiss Plated Nozzles https://store.micro-swiss.com/products/ ... for-up-box, though being coated and not actually a hardened steel nozzle your mileage may vary.
Which would also depend on which heater block you have, they only fit the 8mm variety (After 2015)
I wish tiertime would change to the Olsson styles. I'd buy a new heater block just for that fact. Much more compatibility across the board, and would really open this printer up a bit in regards to printing materials etc.
ajohnsonlaird
Post by ajohnsonlaird » Sun Mar 25, 2018 4:12 pm
Thanks for the reply, brunningm....I'll check out the version of UpStudio I have -- and thanks also for the hardened nozzle link.
Cheers
Andy
