Advanced user settings
SCSRobotics
Post by SCSRobotics » Thu Aug 17, 2017 10:37 am
MUST have advanced user settings mode for the UP Box...... why?
1. need to be able to change the wall thickness and or the number of walls printed.
eg. printed solid walls between 0.8mm and 1.1mm produces an air gap because the printer only prints 0.4mm wide and dosen't infill. (I have trouble printing Lego parts)
printing gears would be better with multiple outer walls or thicker walls to improve strength.
2. more detailed material settings, especially for exotic PLA (wood, aluminium, brass). different flow rates, start temp, print temp.
3. maybe a range of infill methods.
if want to know what I mean, have a look at Cura 2.6.2
