my up box can't initialize and beeping continuously
dzar
Post by dzar » Wed May 17, 2017 10:34 pm
the printer started this problem from the plug in and out of the up box usb cable. the usb cable is hard to plug in and as a result of continuous plugin, i think that it had caused my printer to continuously beeping instead of the normal initialized beep. the colour of the upbox light is still orange not turning to green. the software said that it had a "can't set bulkln timeout" dont know what that means... please help me
tel
Re: my up box can't initialize and beeping continuously
Post by tel » Thu May 18, 2017 11:49 am
Contact support. I had a similar issue and it ended up being a faulty CPU which required a replacement.
3DWP
Post by 3DWP » Sun Nov 05, 2017 6:43 pm
Did you ever get this resolved?
I had the same with my Up Box after uploading a gcode, now my printer will not initialize anymore.
I contacted support but they said my Up Box isn't under warranty anymore :x
extendo
Post by extendo » Sun Jan 27, 2019 10:17 am
My printer is 3 months old if that, mine is doing the same.
Was it definitely the CPU board ?
TiertimeBrook
Post by TiertimeBrook » Mon Jan 28, 2019 12:34 am
@all
Turn off the printer, then move up the platform by manual ,
Check if the platform pressed the limit switch ,
Then try power on and initialize again ,Usually the error can be remove.
extendo
Post by extendo » Sat Feb 02, 2019 5:24 am
Not in this case sorry, I was sent a new CPU which has fixed the issue.
