ABS+ ABS PLA
jack_n
ABS+ ABS PLA
Post by jack_n » Thu Jan 14, 2016 1:12 pm
i would like to ask what the Defaults for the 3 available Materials are.
When a Job is startet i can not see the Temperature of bed an nozzle, i can only see a percentage.
Can someone please tell me the Default temps for bed and nozzle regarding to the 3 Materials?
I tried to print PLA but had no luck doing this, maybe the temps where too wrong...
Thank you very much
Joachim
ricks01
Re: ABS+ ABS PLA
Post by ricks01 » Thu Jan 14, 2016 3:33 pm
Did you use the UP! brand PLA or a third party PLA?
rryerson
Re: ABS+ ABS PLA
Post by rryerson » Thu Jan 14, 2016 9:06 pm
Temperature... both bed and nozzle temp is set when you select the type of filament you are using... There is no other adjustment... There are hacks, but someone else will have to confirm if they work on the Up Box...
jack_n
Re: ABS+ ABS PLA
Post by jack_n » Fri Jan 15, 2016 9:46 am
i used third Party pla, because here in Germany i can not find black pla for the up.
Nevertheless'd i would be very interrsted to know the Default temperatures for the ABS , ABS+ and PLA.
Thank you
Joachim
Tiertime-Jason
Re: ABS+ ABS PLA
Post by Tiertime-Jason » Fri Jan 15, 2016 1:22 pm
PLA is about 210, ABS/ABS+ is about 260.
You can see the temps at the maintenance interface.
Zenitram
Re: ABS+ ABS PLA
Post by Zenitram » Wed Feb 03, 2016 2:36 pm
1st. Instal the tem mod. It works very well.
Set the printer to PLA.
Start by decreasing the 3 tems 5 degees.
Open the extruder window with the tab.
Keep the open window open. Even when printing.
Set the layer to 0.2 mm
Extrude and check the filament. Must flow nice and easy
Play with the temps untill you are happy with the extrded filament.
2nd. Print.
If the raft is too stuck , lower the nozzel height a bit. If is not well stuck move the board up or the temp.
If the raft does not separate well, increase the middle temp and decreasse the 3rd tem.
I hope it helps.
jack_n
Re: ABS+ ABS PLA
Post by jack_n » Fri Feb 05, 2016 11:32 am
thanks for the replies.
What is ment with Temp-Mod ?
The Hardware-Mod or the Software-Mod?
Joachim
ricks01
Re: ABS+ ABS PLA
Post by ricks01 » Fri Feb 05, 2016 5:51 pm
jack_n wrote:Hi,
Joachim
He is referring to the software mod created by mr_x
