Filament sensor
lichtfaenger
Filament sensor
Post by lichtfaenger » Mon Jun 04, 2018 7:20 am
I got a new sensor - to place it i got a instruction. But is there a trick to remove the right side? . i took the 4 screwn off - but how must i remove the side?
Greetings from Germany
Paul
effgee
Re: Filament sensor
Post by effgee » Thu Sep 17, 2020 3:24 am
My filament sensor is jammed (can't feed new filament through), and I'm looking for instructions on accessing it to clear it.
The UP Box+ was certainly not designed with service in mind ! So many inaccessible screw heads, screws fitted from the'wrong' direction for access.
How can I remove the RHS cosmetic panel ?
Preferably without losing my half-finished print.
effgee
Re: Filament sensor
Post by effgee » Fri Sep 18, 2020 5:17 am
OK, I bit the bullet and drilled holes in the side to access the filament sensor mounting screws.
Found a small piece of filament was the thing stopping me feeding new filament either way.
I also found I'd broken the roller lever off the microswitch :(
Can anyone advise the part number or specs for the microswitch ?
