I noticed that the temp reading when just initialized (not heated yet) for my Up Box is always too high. When the table is about 20 the head is just under 50 (47 degrees).. When I reseat the short rainbow cable it fluctuates high values and goes back down but it does print well.
Can anybody check their Box and see if the nozzle and table temps are about the same at room temp? Maybe my cable is faulty..
Up Box Nozzle Room Temp
Re: Up Box Nozzle Room Temp
Hi. In my UP Box, nozzle temp just after initialising the printer is 28,7 degrees ( platform temp 28,5 ).
Probably still warmer than normal temp, because off the sun exposed room where the printer is being kept.
My nozzle reaches around 50 degrees when the platform is heated to 80 degrees.
