Photos:
Any ideas?
?? My platform is 140mm square :p-soapy- wrote:135mm is really beyond the ability of the printer! Heck, that's bigger than the platform!
Give the veroboard solution a try, would be my best suggestion, as the blue tape isn't going to help here, I think.
And where's the raft going to go? It projects ~5mm beyond the end of the part, so really, you can only expect to print a 130mm part on a 140mm platform. Unless you put it at an angle. (I'd love to see someone waste half a pound of material drawing a 1mm thick line 240mm long, just to prove it can be done!!)trebuchet03 wrote:?? My platform is 140mm square :p-soapy- wrote:135mm is really beyond the ability of the printer! Heck, that's bigger than the platform!
He also placed it diagonally
Theoretical:
Maximum 2D diagonal length is 198mm
Maximum 3D diagonal length is just shy of 240mm (almost 9.44 inches!)
^^ Both of those values are for a zero thickness line. Adding thickness decreases theoretical max line length
-soapy- wrote:It projects ~5mm beyond the end of the part, so really, you can only expect to print a 130mm part on a 140mm platform. Unless you put it at an angle.
airborn2 wrote:the part is long, about 135mm so I placed it
diagonally.
Yes, but that's my point - it's unfair to expect a machine to print something out the box that is bigger than the platform size!trebuchet03 wrote:-soapy- wrote:It projects ~5mm beyond the end of the part, so really, you can only expect to print a 130mm part on a 140mm platform. Unless you put it at an angle.airborn2 wrote:the part is long, about 135mm so I placed it
diagonally.
I think you're missing the diagonal point...-soapy- wrote:Yes, but that's my point - it's unfair to expect a machine to print something out the box that is bigger than the platform size!trebuchet03 wrote:airborn2 wrote:the part is long, about 135mm so I placed it
diagonally.
A bit like your car probably has a speedo that goes to 140MPH, but you'll never get it above 110, even downhill with the wind behind you. It's just cheaper to buy the same speedo and put it in all the cars in the range.
If I can fit something in the build envelope, I expect it to print (I used to do this all the time with a Dimension machine - an old 3DS SLA machine too) :p If I have a large part that has a curve length >135mm, why shouldn't it print? The machine is Cartesian, but we control the axes from which tool paths are generated - the machine could care less about the shape so long as the path falls within bounds.-soapy- wrote:I get that you can manage to fit a 135mm long part onto the printer, but, as I say, just because the software will let you do that, you shouldn't expect it to work flawlessly.
