UP Mini raftless ABS printing with PEI success
3DSTB
Post by 3DSTB » Thu Mar 03, 2016 11:39 am
im able to print ABS raftless with no warping with PEI.
Bed has to leveled to no tilt. That was not easy.
This works well with 0.1mm and 0.2mm layer (Soft-Mod). On the Pic is a print with 0.1mm. nozzle must be as close as possible to the bed (0.1mm or little bit less).
jfmateos
Re: UP Mini raftless ABS printing with PEI success
Post by jfmateos » Mon May 16, 2016 12:04 pm
Where did you get the PEI?
I have tested buildtak... it's nice, but get damaged easy and it's quite expensive.
3DSTB
Post by 3DSTB » Mon May 16, 2016 8:02 pm
http://www.amazon.com/Polyetherimide-Na ... B0013HKZTA
you can make 4 boards. Use a 2mm or thicker borosilikat-glass and use 3M 468MP to fix it on the glass.
On PEi you can print also PLA !
jfmateos
Post by jfmateos » Mon May 16, 2016 8:41 pm
Thanks... can it be glued to the original perfboard?
3DSTB
Post by 3DSTB » Tue May 17, 2016 12:25 pm
i dont know.
PEI-howto is here:
https://www.youtube.com/watch?v=Fe-l80z27b4
jfmateos
Post by jfmateos » Tue May 17, 2016 4:55 pm
Thanks, I will try printbite first because buying PEI from Spain in quite expensive.
Woodlake
Post by Woodlake » Wed Jun 22, 2016 3:33 pm
3DSTB wrote: Bed has to leveled to no tilt. That was not easy.
I'm looking at ways to try and do this on my mini.
Can you explain what you did?
arhi
Post by arhi » Wed Jun 22, 2016 7:57 pm
jfmateos wrote:Thanks, I will try printbite first because buying PEI from Spain in quite expensive.
tried, kick ass :D best money ever spent :D
btw, not sure how hot can printbed of the up mini go, you need 120C for the printbite to properly work!
