Octave Temperature Switch Extruder Cover for UP! Mini
Poh
Post by Poh » Sat Jul 27, 2013 10:03 pm
I designed this and thought it would be nice to share this here for anyone who also have bought an Octave Temperature Switch for your UP! Mini 3D printer.
Octave Temperature Switch is originally made for UP! Plus 3D printers only as a non-invasive modification to reduce the nozzle temperature by 30 degrees. Although the switch and its connector is compatible with UP! Mini's extruder, the Octave's switch housing bracket and the UP! Plus extruder cover which the temperature switch rely on are not made for nor compatible with UP! Mini's extruder assembly. Hence, there is no choice but leaving the switch dangling around the extruder. It is an annoying problem during printing, especially on fast printing mode.
You can download it from here: http://www.thingiverse.com/thing:124326 be sure to read the instruction.
