Any interest in hardened nozzles (Group Buy?)
Post questions related to ordering and shipping.
Post by Owen Sparks aka Marksman » Tue Oct 03, 2017 11:34 am
Hi folks.
I understand TT intend to introduce different size nozzles at some stage but I've not seen anything on hardened nozzles.
I'm impressed with some carbon fiber loaded prints I've made on a different machine and thought it's be nice to do the same on the UP printers. (Carbon filament is getting cheaper by the day, but our current soft brass nozzles will be eaten away very quickly if we use it as CF is highly abrasive.)
So I've had a chat to a nozzle manufacturer and they'd be interested in making nozzles for us, but the price is of course dependent on volume.
So with that in mind if you have any interest in custom nozzles please say hello in this thread. Nothing binding, nothing decided yet, just gauging interest.
Last edited by Owen Sparks aka Marksman on Wed Oct 04, 2017 9:41 am, edited 1 time in total.
Re: Any interest in hardened nozzles (Group Buy?)
Post by Owen Sparks aka Marksman » Wed Oct 04, 2017 9:24 am
This just turned up so will test with an old nozzle later today...
RS Carbon Fil.jpg (1.94MiB)Viewed 14099 times
PET-G with carbon, £26 for a 500g roll.
pilo
Post by pilo » Fri Oct 06, 2017 2:43 pm
Hello!
I would love to test
brunningm
Post by brunningm » Sat Oct 07, 2017 9:42 am
I'd be very interested.
Post by Owen Sparks aka Marksman » Sat Oct 21, 2017 12:38 pm
Thanks folks.
I'll leave this thread open for another week or so and then look at getting parts.
Cheers
Kai
Post by Kai » Sat Oct 21, 2017 1:34 pm
Hello Owen,
I am using 3rd party nozzles on the mini for quite some time. The original nozzles are wearing quickly when using metal or carbon filaments. With a special hardened and coated nozzle I am printing many kg without any nozzle wear. See here:
https://store.micro-swiss.com/collectio ... -up-plus-2
There are many other 3rd party nozzles you can use, e.g. the E3D nozzles for 3mm filament work fine as well. There are steel versions readily available.
Kai
Post by Owen Sparks aka Marksman » Sun Oct 22, 2017 9:20 am
Kai wrote:Hello Owen,
Kai
Hi Kai, thanks for taking the time to jump in.
As far as I can see (and I really hope I'm wrong) all the aftermarket hardened nozzles have a course male thread on them. The UPBOX, UPBOX+ and MINI2 all use a nozzle with of all things an M6 Fine female thread. I've not searched extensively but I cant find anything that will work out of the box.
It does raise the thought of making / commissioning an adapter and then using these nozzles. Means it's an one off expense + a greater nozzle offset rather than presumably more expensive bespoke nozzles each time...
I'd value your opinion here.
Kai
Post by Kai » Mon Oct 23, 2017 8:50 pm
Hello Owen,
you are right I still use an old mini with a different nozzle. Great idea though, the issue with such an adapter would be the heat transportation...
Micro Swiss has probably the right nozzle for you here:
https://store.micro-swiss.com/products/ ... for-up-box
Kai
brunningm
Post by brunningm » Tue Oct 24, 2017 12:19 am
I was having that thought this morning myself. I've been looking for some different nozzle sizes for different materials, and the internal threaded ones seem very hard to come by. If we had an adaptor, it would solve so many issues. The only thing I can see as being a problem is nozzle height...but we can adjust for that.
The internal threaded model seems like a step backwards with compatibility...
Post by Owen Sparks aka Marksman » Tue Oct 24, 2017 10:02 am
Morning folks.
Thanks for your thoughts
Kai- Ta for the link. Looks ideal, I'm marking this as "Plan B".
I've decided I like the adapter idea enough to at least try it so I've ordered a hand-full of assorted nozzles and an M6x0.75 set of taps.
Watch this space...
brunningm wrote:The internal threaded model seems like a step backwards with compatibility...
But it is big step forward in the "You'll have to buy our nozzles, and only our nozzles, and at whatever price we think of compatibility" :lol:
Post by Owen Sparks aka Marksman » Tue Oct 24, 2017 2:55 pm
Metal stock also ordered :idea:
O.S.
brunningm
Post by brunningm » Tue Oct 24, 2017 9:49 pm
[quote="OwenSparks"]
Yeah pretty much what I was hinting at.
I did find a 0.5 that might be compatible...it's 6mm internal threaded, but looks a bit odd...8AUD so might be worth the experiment.
https://www.bilby3d.com.au/DispCat.asp? ... bCatID=129
It's at the bottom of that list...can't link to it directly unfortunately.
Post by Owen Sparks aka Marksman » Thu Oct 26, 2017 1:47 pm
brunningm wrote: I did find a 0.5 that might be compatible...it's 6mm internal threaded, but looks a bit odd...8AUD so might be worth the experiment.
Interesting, thanks for posting the link.
O.S.
Post by Owen Sparks aka Marksman » Thu Oct 26, 2017 1:52 pm
OK bits are starting to arrive :)
Rev 0.1 of the adapter isn't looking too robust a solution.
Nozzle Adaptor 0_1.jpg (1.31MiB)Viewed 13859 times
Rev 0.2 might be better once it's finished :roll:
Nozzle Adaptor 0_2.jpg (718.04KiB)Viewed 13859 times
Owen S
Post by Owen Sparks aka Marksman » Fri Oct 27, 2017 11:20 am
Soft Jaws for machine vice printing now...
Nozzle Adaptor SoftJaws.jpg (20.98KiB)Viewed 13833 times
O.S.
tel
Post by tel » Sat Oct 28, 2017 6:53 am
Late to the party but would be interested in a group buy once something is sorted
Post by Owen Sparks aka Marksman » Mon Oct 30, 2017 9:14 am
tegregg wrote:Late to the party but would be interested in a group buy once something is sorted
Hi Tegregg, sure thing. Hopefully we've moved on from custom nozzles to just an adaptor to take standard ones, providing things go well.
Real work is intruding today so only a small update:-
Nozzle Adaptor Soft Jaws Printed.jpg (1.37MiB)Viewed 13784 times
Work-piece holding soft-jaws came out well so we're a small step closer. Taps haven't arrived so will chase that. Hope to cut metal tomorrow.
