Problem with Up! Software on Mac
pocketkk
Post by pocketkk » Sat Jan 07, 2012 11:21 pm
The software loads correctly and I am able to set the height of the platform so I know it is communicating to my Up but after I have loaded the calibration model and hit print the software crashes. I this has happened repeatedly and I have been unable to print at all. I have tried multiple versions of the Up Software and each of them crashes at the same moment. I am in the middle of updating OS X (It hasn't been that long but I want to eliminate that as an issue). Any other ideas? Anyone else run into this? I am running Lion and a 3 year old Macbook Pro.
pocketkk
Re: Problem with Up! Software on Mac
Post by pocketkk » Sun Jan 08, 2012 12:11 am
Tried it with my wife's macbook and had the same result. Crashes after hitting ok on the print dialog.
pocketkk
Post by pocketkk » Sun Jan 08, 2012 12:28 am
It is working. Not sure what did it. Just started from the beginning and this time the software didn't crash. Fingers crossed!
Gozo Bonkers
Post by Gozo Bonkers » Fri Mar 23, 2012 7:13 pm
Hi there
I'm having the exact same problem as you :(
When you say "Just started from the beginning" what does that mean - like did you un-install the software then re-install it?
And what's the best way to un-install the up software on a mac?
Thanks so much :)
Jane
Gozo Bonkers
Post by Gozo Bonkers » Sat Mar 24, 2012 12:34 am
Hey guys, just a wee update.
I re-started my machine, then tried to print and it crashed again. Then i started up the UP software and saved the file as a different name right before print, and then it worked!
Hopefully that may help someone else. Lets hope it keeps working :)
Marcus
Post by Marcus » Sat Mar 24, 2012 4:19 pm
Odd. Still, you may want to send a bug report to PP3DP, perhaps they can figure it out. If two people exeprience similar problems, this might be worth looking into.
TTT험ทดสอบ
Post by TTT험ทดสอบ » Mon Mar 26, 2012 12:49 am
pocketkk wrote:The software loads correctly and I am able to set the height of the platform so I know it is communicating to my Up but after I have loaded the calibration model and hit print the software crashes. I this has happened repeatedly and I have been unable to print at all. I have tried multiple versions of the Up Software and each of them crashes at the same moment. I am in the middle of updating OS X (It hasn't been that long but I want to eliminate that as an issue). Any other ideas? Anyone else run into this? I am running Lion and a 3 year old Macbook Pro.
Hi guys,
We will test the software on more mac systems, and update to V1.4 ASPS.
darkhouse
afe1234
Post by afe1234 » Thu Sep 20, 2012 1:32 pm
Hi, I am unable to use the mac software -- each time it crashes when I try to print. It fails with the stator model and any model I tried.
Here's the crash trace.
Can someone help please?
Exception Type: EXC_ARITHMETIC (SIGFPE)
Exception Codes: EXC_I386_DIV (divide by zero)
Crashed Thread: 3
Thread 0: Dispatch queue: com.apple.main-thread
0 libSystem.B.dylib 0x920e0afa mach_msg_trap + 10
1 libSystem.B.dylib 0x920e1267 mach_msg + 68
2 com.apple.CoreFoundation 0x97f542df __CFRunLoopRun + 2079
3 com.apple.CoreFoundation 0x97f533c4 CFRunLoopRunSpecific + 452
4 com.apple.CoreFoundation 0x97f531f1 CFRunLoopRunInMode + 97
5 com.apple.HIToolbox 0x96932d60 RunCurrentEventLoopInMode + 392
6 com.apple.HIToolbox 0x96932b17 ReceiveNextEventCommon + 354
7 com.apple.HIToolbox 0x9693299c BlockUntilNextEventMatchingListInMode + 81
8 com.apple.AppKit 0x92739595 _DPSNextEvent + 847
9 com.apple.AppKit 0x92738dd6 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 156
10 com.apple.AppKit 0x929b21c9 -[NSApplication _realDoModalLoop:peek:] + 720
11 com.apple.AppKit 0x929b1945 -[NSApplication runModalForWindow:] + 273
12 com.apple.AppKit 0x929a7d41 _NXDoLocalRunAlertPanel + 998
13 com.apple.AppKit 0x929a81f6 NSRunAlertPanel + 69
14 Delta-Micro-Factory-Corp.UP 0x0002e202 -[MacUPView PrintModel:] + 167
15 com.apple.AppKit 0x92777a26 -[NSApplication sendAction:to:from:] + 112
16 com.apple.AppKit 0x927778d9 -[NSMenuItem _corePerformAction] + 435
17 com.apple.AppKit 0x927775ca -[NSCarbonMenuImpl performActionWithHighlightingForItemAtIndex:] + 174
18 com.apple.AppKit 0x927774b6 -[NSMenu performActionForItemAtIndex:] + 65
19 com.apple.AppKit 0x92777469 -[NSMenu _internalPerformActionForItemAtIndex:] + 50
20 com.apple.AppKit 0x927773cf -[NSMenuItem _internalPerformActionThroughMenuIfPossible] + 97
21 com.apple.AppKit 0x92777313 -[NSCarbonMenuImpl _carbonCommandProcessEvent:handlerCallRef:] + 336
22 com.apple.AppKit 0x9276ba55 NSSLMMenuEventHandler + 404
23 com.apple.HIToolbox 0x96905c0f DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1567
24 com.apple.HIToolbox 0x96904ed6 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411
25 com.apple.HIToolbox 0x96927773 SendEventToEventTarget + 52
26 com.apple.HIToolbox 0x96953dc7 SendHICommandEvent(unsigned long, HICommand const*, unsigned long, unsigned long, unsigned char, void const*, OpaqueEventTargetRef*, OpaqueEventTargetRef*, OpaqueEventRef**) + 448
27 com.apple.HIToolbox 0x96978b38 SendMenuCommandWithContextAndModifiers + 66
28 com.apple.HIToolbox 0x96978aef SendMenuItemSelectedEvent + 121
29 com.apple.HIToolbox 0x969789f7 FinishMenuSelection(SelectionData*, MenuResult*, MenuResult*) + 152
30 com.apple.HIToolbox 0x969480ba MenuSelectCore(MenuData*, Point, double, unsigned long, OpaqueMenuRef**, unsigned short*) + 454
31 com.apple.HIToolbox 0x96947815 _HandleMenuSelection2 + 465
32 com.apple.HIToolbox 0x96947633 _HandleMenuSelection + 53
33 com.apple.AppKit 0x92764f96 _NSHandleCarbonMenuEvent + 285
34 com.apple.AppKit 0x92739b46 _DPSNextEvent + 2304
35 com.apple.AppKit 0x92738dd6 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 156
36 com.apple.AppKit 0x926fb1f3 -[NSApplication run] + 821
37 com.apple.AppKit 0x926f3289 NSApplicationMain + 574
38 Delta-Micro-Factory-Corp.UP 0x00002b65 start + 53
Thread 1: Dispatch queue: com.apple.libdispatch-manager
0 libSystem.B.dylib 0x92107382 kevent + 10
1 libSystem.B.dylib 0x92107a9c _dispatch_mgr_invoke + 215
2 libSystem.B.dylib 0x92106f59 _dispatch_queue_invoke + 163
3 libSystem.B.dylib 0x92106cfe _dispatch_worker_thread2 + 240
4 libSystem.B.dylib 0x92106781 _pthread_wqthread + 390
5 libSystem.B.dylib 0x921065c6 start_wqthread + 30
Thread 2: com.apple.CFSocket.private
0 libSystem.B.dylib 0x920ffac6 select$DARWIN_EXTSN + 10
1 com.apple.CoreFoundation 0x97f93c53 __CFSocketManager + 1091
2 libSystem.B.dylib 0x9210e259 _pthread_start + 345
3 libSystem.B.dylib 0x9210e0de thread_start + 34
Thread 3 Crashed:
0 Delta-Micro-Factory-Corp.UP 0x00076363 CPartSlice::CalHatch(CLayer*, double, double, double, int, double, int, int, int) + 829
1 Delta-Micro-Factory-Corp.UP 0x000739e0 CPartSlice::SliceSTL() + 5548
2 Delta-Micro-Factory-Corp.UP 0x00030314 CUPDoc::SliceSTL(int) + 1056
3 Delta-Micro-Factory-Corp.UP 0x0002febe CUPDoc::On3dprintPrint(int, int) + 70
4 Delta-Micro-Factory-Corp.UP 0x0002e601 -[MacUPView PrintThread:] + 135
5 com.apple.Foundation 0x97c084c4 -[NSThread main] + 45
6 com.apple.Foundation 0x97c08474 __NSThread__main__ + 1499
7 libSystem.B.dylib 0x9210e259 _pthread_start + 345
8 libSystem.B.dylib 0x9210e0de thread_start + 34
Thread 4:
0 libSystem.B.dylib 0x9210eaa2 __semwait_signal + 10
1 libSystem.B.dylib 0x9213a9c5 nanosleep$UNIX2003 + 188
2 libSystem.B.dylib 0x9213a903 usleep$UNIX2003 + 61
3 Delta-Micro-Factory-Corp.UP 0x0002e911 -[MacUPView PrintProgressThread:] + 496
4 com.apple.Foundation 0x97c084c4 -[NSThread main] + 45
5 com.apple.Foundation 0x97c08474 __NSThread__main__ + 1499
6 libSystem.B.dylib 0x9210e259 _pthread_start + 345
7 libSystem.B.dylib 0x9210e0de thread_start + 34
Thread 5:
3 com.apple.AppKit 0x928a2e2d -[NSUIHeartBeat _heartBeatThread:] + 2039
afe1234
Post by afe1234 » Thu Sep 20, 2012 1:44 pm
afe1234 wrote:Hi, I am unable to use the mac software -- each time it crashes when I try to print. It fails with the stator model and any model I tried.
Few more details: UP version 1.3 for Mac, and I have Snow Leopard OS X.
Post by JuliaDee » Thu Sep 20, 2012 1:52 pm
I had repeated crashes with Snow Leopard on my MacBook when I first got the printer so I just gave up and put a dedicated Win7 machine on it.
afe1234
Post by afe1234 » Thu Sep 20, 2012 2:57 pm
Julia, thanks for the response! I am now trying with 64-bit Win7 installed on a VirtualBox VM on my Mac.
I was able to initiate the print process for stator model without problems, no crash. But the printer has been with the intermittent red/green front panel light for about an hour now, but no printing has started.
How long does the initialization take? How do I know if something went wrong? The UP software responds to commands, it didn't freeze.
afe1234
Post by afe1234 » Thu Sep 20, 2012 3:38 pm
Just tried with a different model, and it worked!
I noticed the printer did not position the model in the center of the board, as it was in the plan. Is this a known issue? Should I manually recenter the head before starting the process?
Post by wackojacko » Thu Sep 20, 2012 6:54 pm
If this is a Mini it will be fixed hopefully in the next version.
www.3DPrintingSystems.com
nuproto
Post by nuproto » Fri Nov 09, 2012 12:47 am
is this issue fixed... my board is off centered and i installed the mac v1.3
all this info should be posted on the download section.. i keep googling stuff because is not listed on the website
Post by roller » Fri Nov 09, 2012 3:32 am
Just for info. I have used the 1.3 version on Mountain Lion without any issues. I have switched to 1.18 because I need the leveling feature for my Mini but I did quite a lot of printing attempts with the Mac version before that. Worked fine.
