Print at a different start layer
gholland
Post by gholland » Tue Feb 28, 2017 2:09 am
Hi All,
My printer blocked half way through my print.
Is there anyway to start using Up Studio at a different layer than layer 1?
Thanks!
Tiertime_Bryant
Re: Print at a different start layer
Post by Tiertime_Bryant » Tue Feb 28, 2017 2:41 am
The upgraded CPU which have the WI-FI function comes with a new feature of restoring a print job that is interrupted due to electricity cut-off, or unwanted int erruption.It's called "Blackout Recovery"
when your print job is interrupted, after the power restored and the printer initialized, the software will ask if you would like to resume the interrupted print job. Choose Yes and you could continue the work...
Try to restart the printer!
Add:this function can only continue the layer which the program didn't finish...
gholland
Post by gholland » Tue Feb 28, 2017 3:25 am
Ah ok,
So if I have the old CPU and if the extruder blocked then I can't start it. I have to cut the object and then add them together?
Tiertime_Bryant
Post by Tiertime_Bryant » Tue Feb 28, 2017 7:30 am
I am so sorry about it,but based on the latest UP Studio,it is.
tel
Post by tel » Wed Mar 01, 2017 2:45 am
The auto recovery wouldnt fix this anyway. It only works for a power off situation. If the nozzle blocks but the printer continues the auto recovery doesnt let you go back to layer x or to a specific height. It will just start from the power off layer.
