UP Studio For Windows x64 Version:1.5.0.3 Beta
Posted: Thu Jan 05, 2017 11:11 am
by JuanCR
Hi everybody.
You should see new software update with new features:
Re: UP Studio For Windows x64 Version:1.5.0.3 Beta
Posted: Thu Jan 05, 2017 12:11 pm
by Blutgeist
Yes. The new Version of the Windows Software, is a good way in the right direction. I like it. 8-)
But if i print without raft. The first layer is very wavy. Is this right?
Posted: Thu Jan 05, 2017 2:47 pm
by JuanCR
I didn't test it at all...
Posted: Thu Jan 05, 2017 5:30 pm
by JuanCR
Would be nice be able to create more than 7 filament profiles.
Each filament brand has its own extruding temps even for the same material (ABS, Nylon, PLA...)
Posted: Thu Jan 05, 2017 6:59 pm
by kerstman
Raft removal is awesome :)
Posted: Sat Jan 07, 2017 6:38 pm
by 3DWP
I think raft removal has indeed improved, I noticed these things that can also be improved:
- overlap of outer layer and infill, you can see that the bottom layer/underside has some room so more overlap would look better
- calibration screen to calibrate the dimensions of the prints, Up software had this to minimize any offsets - I would very much like to see this back in Up Studio
- Right now all my models are printed about 1 percent too small in X and Y direction. A cube of 20 mm is about 19.8 by 19.8 mm and 20.2 mm high. Models I printed with Up software and not Up Studio had no issues like this and now some parts don't fit because of the offset. I could scale this but a software fix and the ability to calibrate your prints in the software would be great!
Posted: Sun Jan 08, 2017 11:22 am
by tel
The raft removal along with support removal has improved markedly. Is the wheel here to stay? Previously Jason had mentioned that it would be disappearing but there have been a number of updates since and its still there?
Additional infill options are nice, but how about the ability to just pick an infill % and style ourselves. You could have a few predetermined that you could just click on (ie the current ones) and then below that allow us to overwrite that with a keyed in % and a pull down for the type of infill (eg honeycomb)
Posted: Sun Jan 08, 2017 11:58 am
by JuanCR
Has anybody noticed if filament calculation is right?
Yesterday I weighted a used spool and in theory I had enough filament for printing a piece regarding Up Studio calculation of material (say needed 120g Up Studio and 140g real weighted filament, a >8h printing) but when I arrived the print was over at least for 1h, so had to begin again...
Posted: Thu Jan 12, 2017 1:47 pm
by JuanCR
When I create a customized material profile, I cannot reach the bed temp I set, say 90ºC, I cannot get more than 54º.
Posted: Sat Jan 14, 2017 6:28 pm
by kerstman
Is it me or the retraction was modified as well with this update? I started getting stringing in my prints.
LE: The "No support" option seems changed as well. If i select it now, not i don't get any support anymore, not even on the parts i was getting support before (>45 angle) while the option was still checked.
An idea maybe...can we get some sort of info on what exactly changes instead of having to discover these by ourselves at the cost of filament and time lost?
Posted: Mon Jan 16, 2017 10:04 pm
by wackojacko
I see this version allows you to pause at certain heights now - thanks Tiertime! :D
Posted: Tue Jan 17, 2017 12:16 pm
by 3DWP
Couldn't find this sorry, how can that be set? And do you have more info about the new features? A list would be nice indeed :D
wackojacko wrote:I see this version allows you to pause at certain heights now - thanks Tiertime! :D
Posted: Thu Jan 19, 2017 2:47 am
by tel
I think I must be going blind!! Where is this feature. I've looked everywhere (obviously not as I cant find it!) but cant see it.
Terry
Posted: Thu Jan 19, 2017 6:55 am
by Tiertime_Betty
Terry
Please click "Advanced printing", and in that page ,you can set the print parameters(including pause at certain heights and print buffer)
Posted: Thu Jan 19, 2017 1:18 pm
by tel
Thanks. Would never had of found it there!
Posted: Thu Jan 19, 2017 3:51 pm
by ricks01
tegregg wrote:Thanks. Would never had of found it there!
I discovered that after only 10 minutes of playing with the software LOL
