[BUG REPORT] loading stl wrong size
MayuTan
Post by MayuTan » Sat Oct 19, 2013 11:43 am
I have come across a few object made by others in the past that have loaded up super huge
And have now made an object 2mm across, and it loads into the app bigger than the build platform
Object Made with FreeCAD 0.13
scubamatt41
Re: [BUG REPORT] loading stl wrong size
Post by scubamatt41 » Sun Oct 20, 2013 5:55 pm
Sounds like a unit conversion problem? Have you checked that you are not messing up the units?
Always breath out on the way UP
MayuTan
Post by MayuTan » Sun Oct 20, 2013 11:04 pm
I can not find any unit measurements in the UP software
and Freecad does not have any option to change from mm
Post by roller » Mon Oct 21, 2013 12:42 am
It may be other software I am thinking of but I think the Up software upscales if the object is very small, thinking it is a unit error so the object it made 25.4 times bigger (inches -> mm)
TAPPEDOUT
Post by TAPPEDOUT » Mon Oct 21, 2013 2:45 am
I have never had a stl import the wrong size, and tried many.
I'm a Machinist and use GibbsCam to design and export stl files.
For what it's worth.
doraemon
Post by doraemon » Mon Oct 21, 2013 2:53 am
Yes, it does. If you find a part that should be small coming in as humongous, use the Scale and choose 1-->25.4 (might be labeled "in-->mm" or something like that). The UP! software automatically scales things with particularly small parts because it assumes you made a mistake.
MayuTan
Post by MayuTan » Mon Oct 21, 2013 3:00 am
So it changes 2 mm into 5 inches for no apparent reason, I should not have to scale it, and that does not work as the object must be 2mm not a guestimate
I have also had large objects have this problem
This is the first time I have found a reproducible instance to report the bug
I found a 2x4 lego brick on thingiverse once that did it too, but when I made said brick myself in FeeeCAD it was the correct size when loaded into up
Post by DrewPetitclerc » Mon Oct 21, 2013 5:34 am
"1 is the loneliest number you will ever know".
To a computer 1 is 1, it does not know if it is 1 inch, 1 meter or 1 parsec but one thing will always be the same.
Some-one will always ask this question1
"Oh no, I think I saw a 2!"
:ugeek:
:D
:lol:
Drew
Post by mr6k » Mon Oct 21, 2013 3:48 pm
MayuTan
not sure a bout Freecad but I do know that when you create a Sketchup STL file it specifically asks whether you want he STL in mm, cm, metre, feet or inches..
Regardless of the original dimensions, if you draw in mm but "accidently" on export leave the units as inches, then the 3d package file will be correct but the STL will be 25.4 times bigger. I have never had UP software assume a very small STL object file was in inches just because it was only a couple of mm in size. But if it did I guess you just scale it back by 25.4:1 which will return it to an accurate mm size. Well, well, I just tried it created a 1mm x 1mm x2mm cube and 3exported it from sketchup as a mm STL, and yes Up software creates it as though it was 1 x 1 x 2 inches.
TAPPEDOUT
Post by TAPPEDOUT » Mon Oct 21, 2013 7:02 pm
A am always creating STL files in inches, and binary format. In UP software size of object I always import is always in mm.
Yes 1.0 can be 1 inch, mm or mile, unless know what unit intended.
Good luck !
