Base Plate
talk about anything
Locked
cambazz
Base Plate
Post by cambazz » Fri May 06, 2011 6:12 pm
My base plate is no longer usable because one of the threaded holes is no longer threaded thanks to me forcing it too much.
I am inclined to go to the local machine shop and have an identical piece machined from steel.
I wonder if the steel base plate will be too heavy for the pp3dp?
The default one is aluminum, i can have it made from aluminum as well, but then i have to anodize it and stuff.
Any ideas/help/recomendation greatly appreciated.
Best Regards.
virtox
Re: Base Plate
Post by virtox » Fri May 06, 2011 8:36 pm
I fixed an old base plate by taking a few m3 screws, the "sinking?" type.
I drilled out the bit for the screw head and glued the screws in with some epoxy, together with what is left of the thread hold it in place.
I then mount it with a few bushings(?) and wingnuts.
I think a steel plate would increase jitter problems, and the normal and high speed modes would probably loose a lot of steps.
I have ordered a few 14cm aluminium plates myself, I don't bother about anodizing, don't see any point to it really.
Virtox
trebuchet03
Re: Base Plate
Post by trebuchet03 » Sat May 07, 2011 12:44 am
Agreed - don't use steel... It probably can handle the weight, but as virtox said, it's going to exacerbate any vibration as it is a movable part.
Another alternative is to drill the hole out and tap it for a bigger screw with a bit more engagement. Fine threads are not meant for frequent screwing - so go coarse if the option is available.
That said, I like virtox's solution :)
One Offer
Mass Producer
virtox
Re: Base Plate
Post by virtox » Sat May 07, 2011 9:28 am
I'll try to grab some pics.
Oh, and be careful with rethreading though, I eyeballed things on one platform and figured M4 would be an option, it's not ;-)
Unless you also drill into the heater plate :-S
On a side note:
Since I use Kapton tape as adhesive, I lost the need to remove the platform at all.
ata0921
Re: Base Plate
Post by ata0921 » Tue May 10, 2011 6:49 pm
I suggest you just countersink the plate and use nuts to hold it down.
- Andy
Locked
