Max model Size
talk about anything
Locked
ivandd
Max model Size
Post by ivandd » Fri Nov 19, 2010 10:48 am
Hi all
Can you tell me what is the maxium size a model can be. It's probaly me but I can find that spec anywhere on the site.
changfrancis
Re: Max model Size
Post by changfrancis » Fri Nov 19, 2010 12:32 pm
you refering to
140mm X 140mm length
135mm in height
ivandd
Re: Max model Size
Post by ivandd » Fri Nov 19, 2010 4:41 pm
Thanks That's it
-soapy-
Re: Max model Size
Post by -soapy- » Sat Nov 20, 2010 12:36 am
The max height is really easy to reach in a print, the larger X and Y dimensions might give you more trouble.
Locked
