Extruder Stepper Motor not running
BenjaminV
Post by BenjaminV » Wed Jun 14, 2017 5:59 am
The stepper motor of the extruder of my Up Plus 2 does not work properly.
For some reasons, during a print (sometimes at the beginning, sometimes after one hour), the motor stops running. By doing so, it clog the hot end as no new filament is pushed.
The motor is particularly hot which could cause the controller to stop the motor but this behavious appeared just now after more than 2 years of good use...
Any idea on why this is happening and how to fix this ?
Thank you
ftdesigns
Re: Extruder Stepper Motor not running
Post by ftdesigns » Tue Jun 20, 2017 12:21 am
I have one that would stop pushing out plastic randomly. I replaced the extruder motor, it seemed to work for a day, then it happened again. My next try will be to replace the nozzle. I'm thinking that deposits may build up in the nozzle and prevent flow.
JuanCR
Post by JuanCR » Tue Jun 20, 2017 1:55 am
The same happens to my Up Box.
Post by DrewPetitclerc » Tue Jun 20, 2017 6:06 pm
Do you have a plastic "cleaner" installed, the plastic is charged and attracts dust and other stuff that will create a nice plug in the nozzle.
viewtopic.php?f=28&t=753#p5479
JuanCR
Post by JuanCR » Wed Jun 21, 2017 2:04 am
Yes I use a filament cleaner, and it happened even with a fresh opened spool.
Whyrl
Post by Whyrl » Fri Jun 23, 2017 9:18 pm
I used to have problems with this ALL THE TIME....
There were two issues.
One the feed motor would overheat and either stop working OR the filament would become too gooey to feed.
Two when the USB was connected to the computer, it would stop commanding the motor to feed.
For problem 1, I added heatsinks and fans to the feed motor, which made huge improvement in print quality.
and for 2, I still unplug the USB when I'm printing.
I try to unplug it at the 5 beeps when it starts prrinting.
I just downloaded Up Studio and I can't get it to print past the first layer of the raft.
ARG!
S
ftdesigns
Post by ftdesigns » Fri Jun 30, 2017 2:26 pm
Whyrl wrote:For problem 1, I added heatsinks and fans to the feed motor, which made huge improvement in print quality.
Can you please link us to where you buy the heat sinks? I'm very interested in getting some.
