this is the first time my up plus shown error message, error code 011 : the extruder overheat
can anyone help my problem...
pleasee i need my up plus to get normal again..
Most commonly this is caused by a broken wire. It will be the wire that leads to the temp probe on the hotend but the break could be anywhere from the mainboard right to the probe. Check all the plugs are secure especially the rainbow cable that connects the extruder. It wouldn't hurt to unplug and replug a few times just in case it is some kind of corrosion. If you are using a temp mod it may be a faulty wire there or corrosion in a switch. in which case flick the switch a few times or try printing without the mod and see if you get the error.
It may be hard to find the problem but it will usually be in a cable that flexes a lot when the printer is operating rather than one that doesn't need to bend during operation.
