Is this the write power supply for UP! 3D printer?
arasbm
Post by arasbm » Sun Jan 11, 2015 8:15 pm
Someone has donated their UP! 3D printer to our makerspace but it was missing a power supply. I looked online and found this 20v 8amp power supply that looks like it would fit, so I purchased it:
I also have a spare new 4pin connector just like this one (part number: CP-7340-ND) which I got from digikey. I can use that in case voltage arrangement is different with UP! (I dont know why it should be, but just in case)
Is this is the correct adaotor I have or do I need to change the pin arrangements?
If I need to change the connector please tell me what the each of the 4 pins should be.
It is one of the limitted UP! 3D printers that does not have a power switch, not the Up! Plus. I can send you the serial number if you need.
Fred
Re: Is this the write power supply for UP! 3D printer?
Post by Fred » Mon Jan 12, 2015 7:26 pm
My Up uses what seems to be a HP laptop power supply. It should be easy enough to get a replacement. Some info from the label:
HP Model Series HSTNN LA03
PA-1181-02
HP part no. 397648-001
Replace with HP spare part no. 397804-001
19V
9.5A
280W
Post by mb20music » Tue Jan 13, 2015 1:42 am
The power supply has a single pin.
I believe this is what you want...
http://www.ebay.com/itm/AC-Power-Adapte ... 5b0a5f12c4
