Advice on part placement
LonV
Post by LonV » Wed Sep 11, 2013 5:47 am
Attached is a part I've been printing for a friend (to refine it), but it's sort of tricky. Basically it's an ID card holder that you'd wear around your neck for work. So it's got a slot all the way through it. My first instinct is to print it flat, but removing support between the top (where the lanyard hole is) is incredibly difficult. So I've been printing it on it's end, which is a really tall part...and sometimes I get odd distortions, like a shifting slightly from left to right as it increases in height. However, the support removal is pretty easy, because it builds a big support from bottom to top in the middle, but since it's open on top, there's no support wedged in between tiny pieces.
What are your thoughts?
2 images of different angles, and 1 how I've been orienting it:
Screen Shot 2013-09-10 at 10.43.06 PM.png (27.86 KiB) Viewed 5836 times
Screen Shot 2013-09-10 at 10.42.15 PM.png (12.23 KiB) Viewed 5836 times
Screen Shot 2013-09-10 at 10.41.36 PM.png (28.26 KiB) Viewed 5836 times
Ian Smith
Re: Advice on part placement
Post by Ian Smith » Wed Sep 11, 2013 11:20 am
Why not lay it flat, and print it in two halves, and just use acetone or MEK to glue the two together. Minimal support required and the layers are in the right direction to give the object reasonable strength
I've just done a similar thing with some small tabs for mounting a metal frame onto a flat surface
Mounting tab.JPG (34.88 KiB) Viewed 5827 times
amd-tec
Post by amd-tec » Wed Sep 11, 2013 5:03 pm
LonV wrote:Attached is a part I've been printing for a friend (to refine it), but it's sort of tricky. Basically it's an ID card holder that you'd wear around your neck for work. So it's got a slot all the way through it. My first instinct is to print it flat, but removing support between the top (where the lanyard hole is) is incredibly difficult. So I've been printing it on it's end, which is a really tall part...and sometimes I get odd distortions, like a shifting slightly from left to right as it increases in height. However, the support removal is pretty easy, because it builds a big support from bottom to top in the middle, but since it's open on top, there's no support wedged in between tiny pieces.
I would still try print it flat, not sure if allready have done this, but open wind barrier. And try get right tools to remove support,
try different kind of screwdrivers with different length. I have found this kind of screwdriver very handy.
Driver shape
http://www.amd-tec.com
amd-tec
Post by amd-tec » Wed Sep 11, 2013 7:14 pm
One thing more.
Have you tried to use support blocks instead of support? They works also nice in that kind of cases.
Leave 0.2 mm or 0.3 mm cap all over the red block and remove it after printing. See sample pics.
1
block sample.jpg (31.6 KiB) Viewed 5807 times
2
juancr
Post by juancr » Thu Sep 12, 2013 8:07 am
In tall and thin parts I put a heater blowing hot air to the piece to avoid heat tensions which can break those thin walls (be careful of blowing air too much hot :mrgreen: )
Regards,
JuanCR
